Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Radiator.....?
I have had some difficulty finding a post on installing a 944 radiator in a 924S. From what I got from it the 944 rad is a bit larger capacity wise. I would like to know if the 944 rad is the same and if larger can it be installed on a 924S?
TIA
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 08-25-2005, 06:11 AM
The 944 radiator, 944 106 031 03 is the same as the 924S.
You could install the 944 Turbo radiator if you replace the lower support bracket.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-25-2005, 06:30 AM
924Sman's Avatar
Ok perhaps that is what I read. I knew the owner said he ran cooler and now I recall it was a 944na with a 951 rad. You mention the lower bracket and I then recalled the poster said he had to do some work on a bracket to install it.
Ok then 951 rad is what I want, but any info on the lower bracket? Just an added bolt on or fabrication needed?
Thanks!!
Old 08-25-2005, 07:23 AM
