konan's Avatar
85' 944.where is the voltage regulator
Is it built in to the alternator or somewhere else?
Old 08-24-2005, 08:15 PM
bearone2's Avatar
built into the alternator.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 08-24-2005, 08:50 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
its actually bolted onto the back of the alternator
If you remove the air box and the black cone thing on the back of the alternator, it is fairly easy to get to. Two bolts hold it in.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 08-24-2005, 09:14 PM
konan's Avatar
So my charging problem is not related to that either.If the alternator is tested good,what else could cause the problem?
Old 08-25-2005, 04:12 AM
SoCal Driver's Avatar
Oh, I don't know... maybe it's the wires.
Or maybe it's the CONNECTOR AT THE BATTERY???
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-25-2005, 09:18 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
SoCal needs a hug again.
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 08-25-2005, 09:23 AM
No! I don't. I need others to pay attention to what they are told. His other thead remarks about beat up battery terminals that are obviously not stock. You can't charge a battery if you can't get the juice to it.
Old 08-25-2005, 02:54 PM
Gee, lighten up a bit!!
Konan..Do you have any manual for the car? If not, at least get a Haynes!! Electrical systems on cars are highly prone to resistance type problems; dirty or corroded contacts, connectors and so on. The 944 electrical system is marginal at best and must be properly maintained to assure proper operation.
Bob S. former owner of a 1984 silver 944
Old 08-25-2005, 06:30 PM
konan's Avatar
I figured out the problem.The alternator wasn't putting out voltage because the big cable that attaches at the bottom is shorted.I removed it and the alternator started putting out voltage.I ran a line over to the battery and it started charging.Now I must figure out where the cable should go.I have ordered a manual,but it will be a few days.Thanx for the help guys.
Old 08-25-2005, 07:21 PM
