seaboltman's Avatar
Bellhousing Removal Help
Ok well guys i took the engine out of the 87 i have listed in my profile and heres the problem
I need to get this thing onto an engine stand so i can work on it and what not, but the clutch release lever wont let go so i can take the bellhousing off. I did a search and it didnt help me much. i took a picture of the bellhousing, and i believe that the red circled area right about the starter is where theres a bolt i need to remove, but theres no head to the bold, its "filled" almost like the head broke off? Or am i wrong. Someone car to explain (useing the picture i post would be awesome if you want to "show" me what to do. Thanks
1987 944 - Wrecked turned parts car
1986 944 - Awesome Auto
Old 08-24-2005, 11:01 AM
SoCal Driver's Avatar
Reach trough the starter hole and take out the nine bolts holding the pressure plate to the flywheel.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 08-24-2005, 11:09 AM
I don't see any circle in your pic, but I'm pretty sure you are talking about the clutch fork pivot shaft. That gets stuck pretty tight on many cars. Between Rennlist and Pelican there are many threads on problems with this.
Remove the locking bolt on the bellhousing that goes into a grove in the shaft. You will see a threaded hole in the end of the pivot shaft, I believe it is 8mm. That is your key to pulling it out. There are a bunch of solutions but the best two are: get a long threaded 8mm rod and make a slide hammer out of it. Other way is get some bits like sockets and washers that will fit over the shaft diameter and crank an 8mm bolt into the thread and pull the shaft out as you tighten.
I think the slide hammer idea is the best. I didn't do this myself when I replaced the clutch as I could't find a hardware store that had 8mm threaded rod. Just don't bugger up the threads in the pivot rod, then you are in for more money and headache.
If you do bugger up things you can revove the whole works if you go though the starter and inspection holes and remove the 9 triple square bolts that hole the pressure plate to the flywheel. Then you can work on the inside to get the pivot shaft out.
Old 08-24-2005, 11:32 AM
ae1969's Avatar
Send a message via ICQ to ae1969
Slide hammer works........... but I used a 10 pound one........
UNBELIEVEABLE how stuck it gets.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 08-24-2005, 11:51 AM
Once you take off the bell housing with the clutch fork, TO bearing and pressure plate you can get at the fork from the inside.
Old 08-24-2005, 01:28 PM
seaboltman's Avatar
thanks alot guys, i'll be getting it off tomorrow
Old 08-24-2005, 01:38 PM
Back from Beyond
There's an easier way than using a slide hammer. Directly opposite the bolt you're trying to remove there's a port or hole in the bellhousing. Insert a punch of some sort and drive the pin out from here - the back end. Saves alot of grief trying to thread a bolt into the pin and then trying to find room to yank it with a slide hammer.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-25-2005, 11:21 AM
