-   -   a/c wont stay on and pass window stopped working (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/237709-c-wont-stay-pass-window-stopped-working.html)
Texas944 08-24-2005 09:25 PM
the A/C blows cold as long as you hold the a/c button on the dash in by hand. As soon as you let it go the light in the switch goes out and the compressor clutch cuts out. I have checked the high and low side with the gauges and the pressures are spot on - Anyone have any ideas?
Also - the passenger power window quit working - it wont work from either the driver side or passenger side switch! Any ideas on that one please?
pokey 08-24-2005 10:03 PM
On the AC, I'd say it's a bad switch. As for the window, fisrt thing I'd do is disassemble the switches, and clean the contacts with a pencil eraser. Pay close attention to how the pieces all come out.
BananaClip 08-25-2005 12:39 PM
or a dremel with a wire brush. also clean the plugs they go into, and leave one switch together at all times for reference.
