Too Much Info!!
So now that I have my 84 944 (n/a) running just OK, I want to do a good tune up and add some performace to the mix.
So I did a search here on the best plug wires and plugs.. So many opinions I don't know what to choose.
Right now, everything on the car is stock.
So your mission, should you decide to accept it:
With a budget of about $600.00, doing the work yourself (except exhaust work).
And being totally un-familiar with the Porsche (so far) but knows how to turn a wrench.
What would your shopping list look like?
Am I trying to get you to choose my mods and best combo?
Yes.....
Old 08-25-2005, 09:30 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
I have the magnecor wires and they seem to be great.
And when you say its running "just OK" I don't know that I'd suggest any performance mods until its "just right"
;P
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 08-25-2005, 09:40 PM
Well, one thing I know you'll want in that baby after you get her running OK will be a fr wilk chip.
1985.5 na
1986 951 nice; Mine
1986 951 nicer. Hers
These things are addicting....
Old 08-25-2005, 09:48 PM
Eldorado's Avatar
- Wilks chip
- new air filter - (stock or cone.. your choice)
- oil change with the good stuff...
- bank the rest for your first repair....
or.. take the wad and blow it all on checking your belts..... and a new pair of socks.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 08-25-2005, 09:50 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
well, the first thing to do is get your car to optimum running condition in stock form. So, what I would do is:
Oil Change (with the good stuff) - $30, give or take
Cap, rotor, spark plugs - $50, give or take
Air filter - $20
There's your first hundred. If you ask me, the best 944NA upgrade is FRWilk's PowerProm chip. Since you have a 84 car, you will need the adapter board... that combo will run you $300.
TRUST ME, IT'S WORTH IT.
I would personally go after suspension upgrades next. Decent size swaybar upgrades can be had on eBay for pretty cheap (I just purchased a 27mm front bar for $15)... so it really just depends on whatever deals are out there. Stiffer front springs would be a decent upgrade, as would KONI adjustable rears. A front camber brace would also improve handling. Any of these suspension upgrades will probably run $150-250 by themselves.... so chose carefully.
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 08-25-2005, 10:00 PM
ilikemy944's Avatar
And yes, I also have and recommend the fr wilk chip
Brad Tompkins
Old 08-25-2005, 10:49 PM
Baza's Avatar
I'd go for:
1) Belts, 2) Belts, 3) Belts. well its alot more cost effective than the other option (BV club) 4) any suspenion improvements, 5) chip.
My theory is handling is the most important thing as I just love under braking some big HP car into a corner and the out accelerating on the exit. (I love corners).
OH and get yourself a good set of sports sox.
Always start with the cheapest option first
83 NA Guards Red ( Home at last)
2011 Triumph America
Old 08-25-2005, 10:57 PM
OK...
All the fluids are changed as of this week.
Brake system flush, cooling system flush, Motor flush, tranny fluid changed, rear end gear oil changed, everything!
The belt issue was delt with about 500 miles ago.
When I say running just OK, that's because it a little hard to start when cold but fine once it warms up.
So I just wanted to do a tune up but can't decide on which plugs and wires.
Should I go ahead and replace the entire ignition system (coil, dist. with point less ignition), add an MSD, etc......???
What about adding a throttle response cam?
Old 08-26-2005, 04:03 AM
Parrothead member
VINMAN's Avatar
Throttle respnse cams a waste of money in my opinion.
Leave the stock ignition alone, it is fine. Just replace the components.
Vinny
Old 08-26-2005, 04:39 AM
Take the $600 and buy yourself a P9201. (T-belt tool)
You should have a little money to put into Swepco or Redline tranny oil, which will improve your shifting. IMO, shifting is what makes the car slow...the car does 0-50 in 6 seconds, but you have to upshift soon after, which makes 0-60 look worse. My changes are a lot quicker and smoother, and the car feels quicker, even around town.
Old 08-26-2005, 05:26 AM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Best performance items you will get are.....
1. Seat Time
2. Suspension
You will not find a better use for the 600.00 and 600.00 won't buy squat in HP.
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 08-26-2005, 08:13 AM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
I agree with Sman, 600 is worthless in HP but suspension or tires is a good investment. When a 911 leaves you on the straitaway and you catch back up to him on the corners the look on his face is priceless. ;-)
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 08-26-2005, 09:55 AM
Verruckt's Avatar
New shocks! Seat time! Tune up!
The crashes people remember, but drivers remember the near misses. – Mario Andretti
1991 944S2 Rally #951 Rally-America.com
Old 08-26-2005, 02:44 PM
Don 944 LA's Avatar
make sure there the ones with yellow on the toes.
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 08-26-2005, 02:59 PM
pokey's Avatar
Send a message via AIM to pokey
Those would be Koni socks, wouldn't they?
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 08-26-2005, 04:41 PM
Koni Sport socks, the Touring ones are red.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-26-2005, 05:38 PM
Baza's Avatar
Would that be long or short travel
( long or ankle sox)
Old 08-26-2005, 11:54 PM
I always say, your car is only as strong as its weakest link...
Sounds like your tuneup is first...
How many miles on her?
How are the brakes?
Struts?
Go over everything and deem whats needed most...
Good luck/skill!
89 Porsche 944
Owner: AutoFreeFinders.com Online Auto Mall
Old 08-27-2005, 09:10 AM
Politically Incorrect
onZedge's Avatar
I agree with ilikemy944. Running just OK is unacceptable. It should run just right before you consider any modifications. Forget the shopping list for now and make a TO DO list first. I suggest the following:
- make sure the battery is good; get it load tested
- make sure the battery, starter and alternator cable connections are CLEAN AND TIGHT
- make sure ALL the ground connections are CLEAN AND TIGHT; find them all; solder on new ring-tongue connectors and use new stainless steel gound screws or brass nuts as applicable
- identify all devices connected to the DME and make sure all the connectors, plugs and sockets, especially under the hood, are CLEAN AND TIGHT; test and adjust these components as required
- identify all important devices not directly connected to the DME and make sure all the connections are CLEAN AND TIGHT such as the fuel pump, tank level sensors, oil pressure sender, water temperature sender, headlights, gauge cluster and cigarette lighter
This all may sound anal, but no veteran owner would disagree that this will eliminate and prevent many "running just OK" problems. Once the electrical system is "tuned up" and eliminated as a possible cause of a running (or not) problem, troubleshooting the real culprit is greatly simplified. I had a stalling/not starting/rough idling problem and after farting around with the usual "maybe it's the DME relay or maybe it's the flywheel sensors or maybe it's the injectors or maybe it's the AFM or maybe it's the BRT" syndrome for a few days, I decided an electrical system tune-up was in order before I went any further. Turned out to be a failing/intermittent FPR. 60 bucks.
I know all veteran owners are secretly admitting that they really need to do this but have no time. I say: MAKE THE TIME
As for that shopping list and your 600 bucks, I would START with new fuel/air/oil filters, cap/rotor, NGK iridium plugs, Magnecor Electrosports 80 wires, MSD Blaster II coil (use the additional ballast resistor on a stock installation!!), MSD ignition (additional ballast resistor will no longer be needed when the MSD is installed but don't throw it away). Do these in this approximate order one-at-a-time to see how each item improves drivability. Resist the urge to do it all at once or you will never know what the hell it was you did that made your car run "just right". SoCal will probably mention something about belts...
Edek
'87 924S
'91 535i
Old 08-28-2005, 12:40 AM
Burn the fire.
Brando's Avatar
Agreed... tuneup first, toys later.
I'd replace those belts on a newly-purchased car, with the exception that it was done and under warranty of a shop or dealership.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 08-28-2005, 01:39 PM
