konan's Avatar
85' 944 oil pressure problem
I started having a problem with oil pressure,at least on the guage.Has anyone had this problem before?Also the front seal is leaking,would this cause low oil pressure?
Old 08-29-2005, 10:14 AM
Back from Beyond
If you've got a leaking seal, I'd do the front of engine service and then make sure the crank bolt is torqued properly. That bolt needs 155lbs on it to drive the oil pump. Retorquing it will tell you alot.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 08-30-2005, 10:58 AM
