Burn the fire.
Brando's Avatar
Talking "Easier" Clutch replacement proceedure?
I did the clutch on my (dead) 924. In a driveway/parking stall, I could replace the clutch on my 944 in an easier way by...
Disconnect exhaust.
Disconnect shift linkange on trans.
Undo torque tube coupling at trans.
Unbolt trans from the body and torque tube, drop it down, out and under the car.
Unbolt torque tube from bellhousing, slide it back as far as possible with trans out of the car.
Unbolt bellhousing from engine.
Replace clutch cover & clutch disc and pilot bearing.
Reassemble.
Estimation of hours? I think in the neighborhood of 20 by myself. 10-12 with an assistant.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 09-23-2005, 05:46 PM
meister member
speedracing944's Avatar
Make sure to have all the correct tools including the cheese head AKA triple square. Beware of those nasty nasty speed and reference sensors near the top of the bellhousing. Those can consume hours in themselfs trying to get them out without breaking them. 20 hours is about right if everything goes well. The top 2 torque tube to bellhousing bolts can also be a PIA.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-23-2005, 08:23 PM
ae1969's Avatar
Send a message via ICQ to ae1969
Things that will give you grief and things to keep in the back of your mind.
1. The pivot for the clutch fork. Nasty. But there is more than one way to skin that cat.
2. Upper bellhousing bolt. Think universal swivels and extensions.
3. The tranny coupler (if you go and unbolt the tranny from the tranny bellhousing BEFORE you undo the coupler. Not good)
4. Try not to strip anything. Make sure the bolts are clean and wrenches/sockets are seated nicely before putting any force on them.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-23-2005, 08:42 PM
Burn the fire.
Brando's Avatar
Roger that... forgot about the sensors... So used to these infernal Type IV's without them...
This is on my to-do list in a month or so. Thanks for the info
Old 09-24-2005, 09:47 AM
BananaClip's Avatar
Send a message via Yahoo to BananaClip
Originally posted by speedracing944
Speedy
sounds like it
keep the dream alive!
1988 944 NA (purple)
Old 09-24-2005, 01:59 PM
Granite 944's Avatar
"Easier" Clutch replacement proceedure? "
Remove the engine......with bell housing still on......thats my answer. lol
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 09-24-2005, 06:47 PM
