Send a message via AIM to djkoke18 Send a message via Yahoo to djkoke18
Help me So Cal!!
ok timing belt snapped, valves hit pistons, needs to be machined.
heres my question..each dish of the pistons has two 4mm gouges on them;so can i get new valves and have the head machined and put everything back together or do i have to get a new engine?
Old 09-16-2005, 03:11 PM
Just repair the head (new guides, valves machine surface flat) and , replace the belts, rollers, water pump and front seals, change the oil cooler seals while the head is off.
Retension the belts after 2000-2500 miles and then every 15,000 miles (during the maintenance service)
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 09-16-2005, 03:16 PM
ae1969's Avatar
Send a message via ICQ to ae1969
.... to add to that........
I would sand/grind those gouges in order to take off any sharp edges. Its more of an issue on a turbo where you can generate some hot spots....
It may be cheaper to find a used head if you are on a budget.
But if you want to do it the right way. Brit has your answer.
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 09-16-2005, 03:30 PM
You guys dont think the gouges are that serious? i can get the head machined and i already have valves/guides and a gasket set.
Do not use Not because not using Not makes things not as complicated as using Not.
1987 Porsche 924S (Rest in pieces)
1988 Porsche 924S (Current daily driver)
2002 Mazda Protege (Gave to girlfriend as piece offering during one of her cycles
Old 09-16-2005, 10:49 PM
ae1969's Avatar
Nope .......... just battle scars.
Dont do it again.
Old 09-16-2005, 11:54 PM
Ok. This mechanic-guy at Eibell performance told me that those gouges arent too good. I asked whats the worst that could happen? It'll detonate. Detonate? Like a bomb? Yea like a bomb, he says. Oh man! what kind of a work is detonate? He mentioned something about hot spots on the dishes of the pistons. Is this guy right at all? I really dont wanna drive a time bomb! lol
Old 09-17-2005, 08:50 AM
least common denominator
scottmandue's Avatar
Originally posted by djkoke18
Ok. This mechanic-guy at Eibell performance told me that those gouges aren't too good.
Is this the same guy who wants to sell you a set of pistons?
My previous owner blew a timing belt and didn't change the pistons. I have had the car three years and no kaboom.
YMMV
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 09-17-2005, 08:59 AM
Ornery Bastard
"Detonate" means the same thing as "knock" or "ping". And yes, of there are very rough places it could create a small hot spot and lead to knock.
This is what ae1969 was talking about when he said to sand or grind the gouges to remove any sharp edges. As long as you do that, you won't have to worry about detonation.
And if this mechanic wouldn't take the time to explain what he meant by detonate, I wouldn't be taking my car to him. Good mechanic or not, he doesn't seem interested in being entirely forthright just based on what you've said.
Aaron
Silver 1998 Volvo S70 T5 <- Daily (Anja)
Guards Red 1986 951 <- Seattle car (Gretchen)
White 1976 914 2.0 F.I. <- Prodigal car, traded away then brought back again (Lorelei)
Old 09-17-2005, 09:36 AM
Hmmm...very good points made. Ok ill keep the engine. Now, how do I, and with what tools do I grind the Pistons with? And how deep can I grind without causeing harm?
thank you everyone for all your input!
Old 09-17-2005, 09:47 AM
Ornery Bastard
Check with one of the others on that one. I'm only about 90% certain that the answer I'd give would be right so I don't want to give it.
Aaron
Old 09-17-2005, 09:55 AM
