How does the sun roof work?
Vaccumm right?
Just got the car back from getting ALOT of work done and now the sun roof isn't working.
They did a brake system flush, could that have anything to do with it?
Right now I can push it up and the console button does nothing.
Checked fuses, they are ok.
Old 09-17-2005, 09:22 AM
natey's Avatar
Hey, a question I can answer...
No, the sunroof doesn't use vaccuum. If this is a late-model 944, there is a small electric motor mounted in the back hatch area (inside the car), behind the rear driver's side wheel well. This motor turns a cam, which in turn pushes or pulls on a (steel?) cable, which has a spring coiled around it. This cable sits inside a plastic sheath, which runs up the drivers side C-pillar and through the two lifter arm gear boxes on the roof. As the spring is pushed or pulled sideways through the gear boxes, it turns the gears, which move the lifter arms. Which is probably more than you really needed to know.
Anyway, it seems to me like having the brakes bled should have no impact on the sunroof. If they did anything in the rear hatch area under the carpet, they may have knocked an electrical connector loose or moved the cable+sheath, causing the cable to bind (?). But I'd guess the problem is electrical in nature, something not re-connected properly, etc.
1988 944NA (Someone else's problem now)
1989 951 "Serena" (Still miss this one...)
2006 330i "Shadow" (6 speed, sport package, and nothing else)
2009 X3 "Ruby" (Because it snows here, and I have things to move)
Old 09-17-2005, 01:29 PM
Granite 944's Avatar
Try here. Look under sunroof.
Clark's garage index
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 09-17-2005, 02:51 PM
The answer is just a mouse click away: 944 Sunroof Operation
Cliff Hipsher
'87 944 India Red
'86 951 Kalahari Metallic
Old 09-18-2005, 06:36 AM
