Porsche Crest I hear you knocking
Hi new friends.
I am a new (used) Porsche owner and this is my first time on the forum so be gentle.
I just bought an '88 924S that is in near mint condition. Did I say bought I mean stole. The doctor my wife works for gave it to me for $650 because he didn't have room for it next to his new Lotus.
Anyway, the only problem I have found is that when I down-shift I get a thumping sound from the drivetrane. I can't localize it but I think it from around the tranny or it could be the shaft from the engine. It is only on down-shift except I hear a small "chunk" sound on up-shift. I took it to a local shade-tree Porsche mechanic and he said don't worry about it.
I checked the drive shafts and CVs, they seem solid. Any thoughts to help out a new member of the club.
s.herald
Old 09-20-2005, 03:22 PM
Don 944 LA's Avatar
rubber donut ????
hitting the metal " stops" ???
if so, a clutch may be in your immediate future, however, I drove on mine like that for 9 months of 200-400 miles a day until it finally went..
It was about $1900 for a shop to do it. Way cheaper if you do it yourself before it actually goes and you have no choice but to bendover ...
Congrats on the purchase btw, and you will find that there are a few things that every newly purchased P-Car needs to set your mind at ease ...
People will be asking you when the timing belt was last changed or tensioned etc ....
All in all once you get past the initial " wierd problems" you will love that car !!!
Good luck & Welcome
Don
944 85.0 Kalahari Beige -- Dead/Gone/NotForgotten (Ran Like a Raped Banshee) 944 85.5 Guards Red
Current Stable 944 83 Kalahari Beige manual rack, short 5th gear951 86 Guards Red, pristine TurboYou must not anger the Porsche Gods - you MUST leave one small item unrepaired, lest the Stuttgartians smite thine car with bad Ju-Ju-AF Juvat
Old 09-20-2005, 03:32 PM
how many miles? on it?
1988 924s mars red
coastal cruzer
Old 09-20-2005, 04:34 PM
..P ..P is offline
Get ALL the records, FIND evidence of timing belt adjustment and replacement. Otherwise you must replace the timing belt to be sure of what you have, otherwise you're just rolling the dice with that cylinder head because if that timing belt break$ you're in for $ome real ca$h outlay. That' way you know what you have and you won't have to worry about it.
T belts are judged by TIME and Miles, so don't just let the miles dictate. When I bought my two 944s and my 928, I had each of the timing belts done immediately, and all the other belts and hoses changed out, just to clear the decks.
Replace the fuel injection and other critical relays, because these have a life span somewhere around 20 years (or so, depending upon humidity). Otherwise the motor could shut down like the lights going out.
The noise you hear could be the clutch as noted, but further inspection may be necessary. The clunk sound sounds like a bad original spec clutch disc.
Even at those costs, potentially costing you $3000, the car is worth it
regards, P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 09-20-2005, 04:55 PM
Thanks for the inputs.
Cruzer,
She has 149,000 miles.
P,
I'm way ahead of you on the belts. I have an appointment tomorrow with a good P-mechanic ( he use to be a senior mechanic with the Porsche Raceing Team). The lower belt is showing some bad wear so since those belts are coming off anyway I'm going to do the timing belts also.
S.Herald
S. Herald
NASA Engineer
1988 924S
Bought as a fix-up and sell,
but fell in love.
Old 09-20-2005, 05:40 PM
Zero10's Avatar
Send a message via ICQ to Zero10
The clunk is probably transmission mounts. If it was the rubber center on the clutch (providing the clutch has not been changed in several years, since the rubber donut clutches are antiquated), you would have severe drivetrain backlash, and it would be difficult to drive.
T-Belts are the biggest killer of 944's. I've seen so many head to the wrecker because the belts weren't changed, and people can't afford to rebuild the head. Just be certain to keep up on it.
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 09-20-2005, 08:15 PM
Do a search under "Potential expensive drivetrain klunk". I had the clutch centre rubber go and had useful feedback from guys like Socal, Idontknow etc. It will also describe how to check if it is the rubber centre gone.
Old 09-20-2005, 11:42 PM
Tapage's Avatar
Send a message via ICQ to Tapage Send a message via AIM to Tapage Send a message via Yahoo to Tapage
Cruzer,
A lots of miles .. always when I see user car, I see the interior, carpets, mats, dash, it's give me an idea of the owner care.
David Alonso De La Vega Tapage
Panama
944 Turbo
Old 09-21-2005, 10:03 AM
The interrior is perfect except for a tear in the drivers seat cloth. The owner was a Doctor that had a lot of money to keep it up. That is why I knew this was a good deal.
Update: The clutch, PP, and TO bearing were replaced in 1997 to get rid of the rubber donut. I found a great P-mechanic and he is convinced that the thumping is a CV. He is also changing out the timing belts and the front belts.
Old 09-21-2005, 04:06 PM
Sounds like clutch to me, but is the exhaust system fully secure?
When i bought my first 924 it was only held on by the manifold and the rear backbox bracket with nothing securing it in between.The result was when either putting my foot down or changing down the centre section would vibrate and knock on the underneath of the car.I honestly thought the engine was knackered until i checked it out.
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 09-22-2005, 02:33 AM
