Tapage's Avatar
Send a message via ICQ to Tapage Send a message via AIM to Tapage Send a message via Yahoo to Tapage
Clutch Pedal - Stuck
Well Today star little problem in my Porsche, with running engine, and hot ( normal operating temp ) the clutch pedal each time when I try to engage any speed the pedal remins down .. need tu pull up with the foot.
when the engine is cold of stop all is fine ( normal ) hydraulic problem .. slave, master . ?
David Alonso De La Vega Tapage
Panama
944 Turbo
Old 09-23-2005, 02:04 PM
Eldorado's Avatar
another candidate for a slave/master replacement.
check your brake fluid level.... if it's low, top it up..
you can even bleed the system if you like to remove any air... this might fix it as well...
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 09-23-2005, 02:12 PM
Tapage's Avatar
I purge the system mmm 2 weeks ago, when replace all clutch kit, disk, plate, bearing, fork.
Well replace master and slave .. I will be check tomorrow air on the system agian .. but is not a issue, no matter what replacement.
Panama
944 Turbo
Old 09-23-2005, 02:32 PM
Tapage's Avatar
update .. on saturday change the slave .. and solved .. !
Panama
944 Turbo
Old 09-26-2005, 03:01 PM
Eldorado's Avatar
congrats...
Kyle
Old 09-26-2005, 03:45 PM
Tapage's Avatar
Also was chage the oil sender unit .. ( my oil press gaugle it was stuck at top ) and now function fine ..
Panama
944 Turbo
Old 09-27-2005, 09:16 AM
