-   -   A/C Recirculation Question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/242857-c-recirculation-question.html)
nomorerx7 09-25-2005 02:22 PM
Whenever I press the A/C button on my 89 951, the recirculation flaps close so that the inside air recirculates. This happens regardless of whether I have the recirculation button pressed or not. If the recirculation button is not pressed and the A/C button is not, then the flaps open for fresh air. Is it normal for recirculation to be forced when the A/C button is pressed? Could the temperature sensor being affecting this? Any ideas how to fix it?
Thanks,
Mark
Porsche944 09-27-2005 06:11 AM
Sounds like there is a problem with the climate control electronics. The recirc flapper should not close unless the recirc button is pushed.
nomorerx7 09-27-2005 07:50 AM
I was afraid of that, but I was hoping I was wrong.
Thanks,
Mark
