Send a message via Yahoo to Cebu
Brakes soft
85.5 944 NA.. I am able to bleed the air from the left rear, left front, and right front after replacing both front calipers and rotors. Unable to get all the air out of right rear caliper. It just keep pumping air bubbles. Please advise...Thanks.
85.5 944na
Automatic
V-65 Magna
94 Impala SS
Old 09-27-2005, 03:22 PM
Z-man's Avatar
Make sure to keep an eye on the brake fluid reservior - if it goes low, you'll just be pushing air through the system.
Check for leaks as well
Start with the passenger rear, then driver rear, then passenger front, then driver front corner.
Keep at it - if you went low on the brake fluid, you probably sucked a lot of air into the system.
-Z-man.
1989 944S2 - June, 2001 - January, 2014
Visit my homepage!
Old 09-27-2005, 05:53 PM
