livewirevoodoo's Avatar
Under Dash Vacuum Lines 85.5+
What are the under dash vacuum lines for?
With the glove box removed, I see approx. 4 small diameter vacuum lines. 2 seem to come from then engine side of the firewall (where??)
The other 2 are "local" to under the dash. One has a "Y" connector. All in pretty bad shape.
Would like to replace after the torrential rains stop. I don't see these lines depicted on the vacuum diagrams tho. Any info on these lines anyone?
Thanks in advance.
''87 944na 85k
C02 / M158 / M418 / M425 / M431 / M454 / M533 / M650 / M946
'94 Oldsmobile 88 Royale (winter beater)
Its not what you drive, its what drives you.
Old 10-14-2005, 06:17 PM
I think the vacuum line that goes into the firewall only run the fresh/recirculate flappers in the outside portion of the HVAC system
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 10-15-2005, 05:07 AM
