Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
A clutching situation!
Well my car died right after its 3rd time across the country. I had 3 votes R&P and 2 votes clutch. Well after much time and effort in a parking lot I finally got the clutch out. I will post pictures. Needless to say before i got it off i was being hit with pieces of rubber. I have a spare tranny that i will be putting in with a short shift and all. The TT probibly will be rebuilt, new exhaust, and most importantly a new clutch, spring centered. I am unsure what to do with the flywheel, i dont think that it is warped but it may be grooved a little bit. I should probibly pull it off to check it. The pressure plate had a date of 92. most of the miles were put on the car before then and i bought it with 150K it now has 191K I dont remember a recipt for the clutch but i would guess 80-100K.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 09-10-2005, 01:41 PM
Will work for parts
944 boy's Avatar
Old 09-10-2005, 01:50 PM
Send a message via AIM to michaelathome Send a message via Yahoo to michaelathome
Thanks for the pics, I was wondering what it looked like in there, my clutch is clunking on my 87 and I know that the center is broken. I will be replacing with a spring clutch this winter I think.
Michael
Old 09-10-2005, 02:27 PM
SoCal Driver's Avatar
Bet you don't make it to "this winter". A broken center clutch may last two weeks, maybe a month of regular driving.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 09-10-2005, 02:34 PM
Will work for parts
944 boy's Avatar
i just pulled the flywheel. I dont have pics of that, i may later. At what point should it be resurfaced and at what point should it be replaced. It is smooth without much groving at all. But what worries me is the colors of it. It looks like it has gotten quite hot at a few points in its life and there is one patch of color that is the size of a dime run over by a train. I would love to replace it with a fidanza but thats expensive. I have also just heard that a light flywheel could cause probelms when racing. Something about the motor spooling too fast and the DME would loose track of the engine sensors while shifting. I dont know if that is true or not. I have to check how this this flywheel is first off.
Old 09-10-2005, 03:38 PM
Composite Shop Owner, DJ
MixMasterK's Avatar
Send a message via MSN to MixMasterK Send a message via Yahoo to MixMasterK
When I got my car, I could tell the rubber was busted. I was able to drive it for about 2.5 months until I could get it in the shop for service. However, I don't recommend going that long.
'86 944, 5 Speed (Daily Driver)
Old 09-10-2005, 08:13 PM
Many don't recognize a busted clutch rubber and drive it hard. Over two months is pure luck.
I've had to put mine back together with the same pressure plate and flywheel due to severe lack of funds. Gets a little funky when hot in stop and go traffic.
Old 09-11-2005, 12:05 AM
Burn the fire.
Brando's Avatar
Well BUTT*****!
Looks like you gone bought a clutch
The dead clutch was a rubber center? Looks like it...
Question about clutch longetivity... A spring-center with broken springs is guesstimated to last how long with delicate driving?
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 09-11-2005, 12:19 AM
To the rivits.
Old 09-11-2005, 12:21 AM
Burn the fire.
Brando's Avatar
Wow, that's a releif. The rev-limiter and I are becoming close friends....
Old 09-11-2005, 12:43 AM
pull the flywheel, take it to a machine shop and get it measured and turned. It costs about $40. Replace the 9 bolts and the rear seal since you are in there.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 09-11-2005, 04:26 AM
Burn the fire.
Brando's Avatar
Since you have the thing off... Lighten it a bit. Stock flywheel weight minus 5lbs maybe?
Old 09-11-2005, 09:47 AM
Really not worth the trouble to get them lightened. The flywheels have a certain weight/inertia for a reason.
Old 09-11-2005, 10:24 AM
dweymer's Avatar
How would one know the center is going?
EDIT: nevermind, searched it.
Donnie
Currently Porsche-less.....
Old 09-28-2005, 08:51 PM
