fuel pressure guage question
Does anybody know the thread size on the fuel rail test port? i bought a guage and need to get an adaptor
Old 10-01-2005, 07:53 AM
Granite 944's Avatar
Haynes manual says its a 11 X 1.5mm adapter needed. I just used an extra rail cap, drilled it for a connector for my pressure gage. I think Skip from paragon products has a write up on doing this.
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 10-01-2005, 08:00 AM
is it a normal pipe thread?
Old 10-01-2005, 08:10 AM
That I'm not sure of. Someone else who knows for sure? I doubt its a pipe thread though. Most likely just a straight metric tubing thread. Pipe threads are a tapered type thread, tubing threads are not.
Old 10-01-2005, 08:14 AM
Parrothead member
VINMAN's Avatar
metric thread, not a standard pipe thread
Vinny
Old 10-01-2005, 02:31 PM
meister member
speedracing944's Avatar
I drilled a cap as well but couldn't get it to seal off very well. Do you have any hints?
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 10-01-2005, 07:31 PM
I use an O-ring between rail and cap when using it. I have a cheapie O-ring kit I purchased from Harbor Freight tools. Not much torque on the cap needed while doing this.
Old 10-01-2005, 10:55 PM
meister member
AAhhhhh. Thanks... I'll try that
Old 10-03-2005, 06:45 AM
