cchyper's Avatar
Send a message via AIM to cchyper Send a message via Yahoo to cchyper
FrWilk Chip Question and Report
I bought a FRWilk Chip last week and installed it the other day. I can feel and see the following:
- Smoother higher idle (Just below 900 RPM)
- Stronger Lower End
- Harder Pull
- 7000 Rpm Rev Limiter
Question:
I installed a switch for the altitude sensor jumper. When I switch the switch to it should go back to the stock map. Correct? Except the rev limiter stays at 7,000.
I have only taken it up to about 6800 so i havent tested to see if there is a rev limiter at 7,000. I guess i should grow some cahones and try it out.
Old 10-03-2005, 01:46 PM
Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
I wouldn't keep the car at 6800 for very long.
Also, you could have adjusted the idle at any time, with or without the chip. There is a flathead screw below and to the left of the throttle cam on the throttle body. Turn it one way, higher idle; other way, lower idle.
That being said, the PowerProm is still the best 944 upgrade I have come across.
Current Stable: Black 07 Porsche Cayman S: FabSpeed Maxflo Exhaust; VividRacing ECU Tune; IPD Competition Plenum; 997GT3 Throttle Body; De-Snork'd.2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Silver 09 Mini Cooper S ("Mighty Mouse"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. Green 97 Volvo 850 Wagon ("The Viridian Falcon").
Old 10-03-2005, 02:25 PM
That Guy
Techno Duck's Avatar
With the switch off, you are running stock fuel maps. Its evident if you switch off while the car is on the fly. You can really feel the differnce in lower end power.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-03-2005, 07:26 PM
fast924S's Avatar
Send a message via AIM to fast924S
Make sure you hooked up the switch right and know which way is on and off. With the switch off you should be running stock maps. When you switch the switch on the DME looks for the High Altitude maps which FR-wilk has swapped with a peformance map. So this is how i Believe it to work the stock maps where never touched the chip you swapped was the High altitude map chip. Also like CJ said, I wouldnt get all rev happy all the time just be careful.
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 10-03-2005, 07:52 PM
cchyper's Avatar
I will try switching on the fly next time. Tell you the difference.
Old 10-03-2005, 09:30 PM
