balance shaft plug
i own an 87na and doing the upper balance shaft cover. there's a plug on the bearing area of the cover with a rubber o ring under it and i think it's used for oiling of the turbo model. uppon replacing the rubber plug o ring i find myself wondering how much torque i need to apply to the plug. i can't find it on the manual, although it does mention replacing the o ring on every cover reseal. hope someone has this info. thanks in advance
jiriarte |
