Dam Hose clamp
I am trying to take of my upper rad hose and the f@##^^@$ gentle man before me put it on in such a fassion that it cannot be un tightened. Meaning you cannot get the screw driver in there to lossen the dam thing!!! Any suggestions. I am not in a situation where I can lift the car and I need to get this dam thing of ASAP!!
Any tips?
83 944na
Old 10-13-2005, 06:24 AM
That Guy
Techno Duck's Avatar
Which side are you refering to, the block or radiator side? If its the block side, take a dremel and carefully cut the hoseclamp off. If its the radiator side, raising the headlights may provide more space. You may consider removing the airbox bracket if you havent already done this.
How is the clamp oriented, can you be more specific?
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 10-13-2005, 06:51 AM
It is the rad side and I have tried rasing the headlights that helps a little. The hose clamp is pointing down towards the engine. I don't know how it could have been tightened in this position. There is very little room to do anything!! I think removing the air box bracket is the next step. I have tried but I think the bolt is rusted pretty bad and I wanted to leave it alone!
83 944na
Old 10-13-2005, 08:09 AM
bryanthompson's Avatar
Send a message via ICQ to bryanthompson
After taking the fans off, I was able to get to that clamp from underneath the car with a stub screwdriver. If yours has a hex head, maybe you can find a socket to fit and get to it from underneath? When I reinstalled, I made sure to orient the clamp so I could get to it from the top for next time
1983 944 - Sable Brown Metallic / Saratoga / LSD : IceShark Light Kit
Old 10-13-2005, 08:23 AM
That Guy
Just to add, removing the radiator fans takes about 10 minutes, very simple to do. Just 6 nuts holding it on.
Jon
Old 10-13-2005, 09:03 AM
thanks!
83 944na
Old 10-13-2005, 09:20 AM
