-   -   No Temp Reading & No Fan (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/245964-no-temp-reading-no-fan.html)
eresener 10-13-2005 06:37 PM
Drove down to the License Branch yesterday ( about 26 miles rt) to get my new tag and noticed that I didn't have any temp reading on the gauage. Got home and it was unusal for the fan not to be running after I shut off the car. Can anybody give me a clue as to what to look for...??
Started up and runs fine...even gave me plenty of heat tonight out on a short run...10-15 minutes...yet no temp nor fans again...this just started happening this week...
Gene Alvarez 10-13-2005 08:23 PM
Seems odd...the thermo switch that controls the fan is completely separate from the sensor that drives the gauge inside. You could verify that the thermo switch still works with a volt meter and a pot of boiling water.
You say the heater heats, otherwise one would suspect the thermostat at the water pump stuck open.
eresener 10-17-2005 02:32 AM
Thanks Gene,
I will try this tonight...sorry I did not respond sooner...went out of town early the next AM...not in my 944...and just returned last night...
TIA...
Ed
eresener 10-19-2005 03:14 AM
Well I have seen stranger things but...went out last night for another "test" drive...when I returned (25 minutes) from this run...not at all hard on the pedal...and turned off the engine...the fans were running as normal..yet still no temp guage...what is next??? help.
