emissions 84' 944 A/T
I have an 84 944. I failed an emissions test and I am at my wits end. I replaced the Cat, plugs, O2 sensor, wires, distributer, rotor and air filter. I am .14 above the limit of 2.00. I don't think I have any vacuum leaks and I topped off with 92 octane. I never had problems before and was wondering if there is a throttle positioning sensor and an egr valve on this. The Haynes manual doesn't show them being installed.
Old 06-07-2005, 06:31 PM
SoCal Driver's Avatar
No egr valve. Throttle switch just shuts off the fuel on till the engine is below 1200-1300 rpm.
Check the limits from the last time you had to do smog. Bet they have been lowered.
Also what is .14 and 2.00??? NOx? CO? CO2? HC? What are the other readings?
You might want to visit www.frwilk.com and read about retracking the AFS (air flow sensor).
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 06-07-2005, 07:18 PM
Re: emissions 84' 944 A/T
So close but yet so far!!! Sounds like you have covered the basic that usually causes failed emmissions.
Try checking:
1) All the vacumn hoses. I once had a disconnected hose going to a big black thing (technical term) in the battery compartment area.
2) If your adjustment screw on your AFM was messed with then this will cause you to fail, symtom: the rubber plug is missing from the AFM. Using an allen key turn the adjustment screw clock wise until it stops (remember to keep track of the # of turns as reference). Unscrew (counter-clockwise) the adjustment screw and set it to 7.5 to 8 turns from the bottom and take it for the test.
3) If number (2) does NOT work it could be that the spring for the "barm door" in the AFM is stretched out and needs to be reindexed 1 notch. It could be the wiper arm adjustment like SoCal suggested, if you have to remove the black cover to do this then remember to use O2 sensor safe silicone to reseal it. If you don't want to do this then buy a used AFM or swap with someone.
4) If you are at your absolute wits end, you can run the gas to almost nothing and then put in a mixture of 1 to 2 gallon of 87 octane and 2 quarts of gas line antifreeze (alchol), then take it for the test. Sorry to all the wood fairies out there but Guranted pass!!!
Mark
'86 944NA
'10 VW Golf 2.5 5sp
'99 BMW 540i Sport Wagon
Old 06-07-2005, 07:54 PM
I'm in Westchester.....my 84 passed on the second run........It failed on the first run.....my mechanic says the secret to passing is to run the cats till they're red hot.......make sure you hot wire the fans so they are both on.....and take it to the station after a long hot run......good luck
Old 06-07-2005, 08:36 PM
pokey's Avatar
Send a message via AIM to pokey
First, run your car nearly out of gas. Then fill up with 87 octane. High octane gas does nothing but burn cooler and slower, and being as your engine is tuned for 87, it will be less efficient and cause more pollution on higher octane. The owners manual has a good description of why, and what gas to run. It says, in the US 87 octane is the same as Europe's 91 octane, because there are different standards of measure, that is why your gas door has a sticker that reads "91 RON" that is the european furmula.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 06-07-2005, 08:53 PM
The adjustment on the AFS is for idle only. Once the barn door opens the bypass is moot.
Still would like to see all your numbers properly referenced.
Old 06-07-2005, 09:32 PM
I failed on the nOX. My reading was 2.14 and the limit is 2.00.
Old 06-08-2005, 02:07 AM
Eldorado's Avatar
gotta love living in Ontario - no emissions tests on cars older than 20 years old!
granted, those are probably the cars that NEED testing... :S
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 06-08-2005, 05:17 AM
Ya I hope they stay the course as this spring was my last unless they get wise.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
Old 06-08-2005, 09:31 AM
High NOX, the car is running lean or you have very high combustion temperatures.
Try what user426 posted that may help you get the pass. Clean injectors are always a good thing too.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
Old 06-08-2005, 09:40 AM
The some smog test like where I live samples both at idle and at 2500 rpm.
Mark
'86 944NA
'10 VW Golf 2.5 5sp
Old 06-08-2005, 02:47 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
I have the same car. I have faced and am facing the same prob you do. Bad for two reasons
  • failing smog sucks. No tab=more expense, not legal, routine traffic stop auto target, DUI check points=ticket or tow
  • Now yer tagged as a gross poluter (at least in CA)=Smog test EVERY year. Gen. drag
    Solution: Find a P-car dealer that does smog and has the impression that you'll be a loyal cust. Mine was $80. Best money I've spent on her yet.
  • __________________
    *Disclaimer: The person above is actually dumber than he appears.
    my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
    '84 944 auto/ps/ac/cc
    '86 951
    Providing ignorance one post at a time.
    Old 06-08-2005, 06:12 PM
    todwic's Avatar
    Or you can have the check done when yer almost on empty, throw in a bottle of rubbing alcohol in the tank. Worked on my turbo, the N/A is next. (per Auntie Wilk)
    '86 951
    Old 06-08-2005, 06:14 PM
    I have just aquired an '86 944, failed emissions as well.
    the NOx, HC, and CO2 tested well within limits, but the CO is off the charts at sta
    Old 06-14-2005, 07:49 AM
    the NOx, HC, and CO2 tested well within limits, but the CO is off the charts at start of test, then drops down.
    I have been running High Octane...mistake? should i be running 87???
    Please help if you can I have a week before registration is suspended!!!
    thanks.
    Old 06-14-2005, 07:51 AM
    Post the actual test numbers as there is a relationship between them. You may be able to adjust the DME timimg to compensate.
    Old 06-14-2005, 07:59 AM
    NOx = 1.74 limit = 3.25
    HC = 2.10 limit = 2.25
    CO = 68.15 limit =23.74
    the CO2 787.09 no max limit
    thanks!
    Old 06-14-2005, 09:22 AM
    Send a message via Yahoo to bigyagi
    not sure if its any help, but check my new posting, under emissions. i have added my last test results, albeit for ontario, but it shows the various tests they do. i dont think they even checked my cat!!
    bob.
    1984 944 na.
    FR. WILK power prom/dual chip.
    2005 buick. daily beater
    2002 grand am--better halfs ride.
    olds 98 royal brougham--gone, but not forgotten.
    Old 06-14-2005, 11:13 AM
    Thanks BIG TiME!! Just signed up to Pelican and want to say you folks are great! Really happy with my Guards Red RIDE.
    Marc
    Old 06-14-2005, 11:25 AM
    Does 87 octane plus alcohol have adverse effects on the engine? I just failed the emissions test today in my 1984 944 with high hydrocarbons and CO. NOx was luckily fine.
    84 Porsche 944..its why im here
    95 Ford F-150
    98 Jeep Wrangler TJ
    Double 0 Alero. Alright! something from this millenium
    Old 10-19-2005, 09:56 AM
