Who sells track suspension components for 944's
I would like to get some stiffer coil springs for the front, rear torsions (which our host carries), and possibly some other mods. I want the car biased more towards DE/Track use but livable on the street (I have a high threshold
). Does anyone have recommendations for a dual-use car biased more towards track use in terms of front coils/rear torsion bars? I am leaning toward running Bilsteins all around. Any other recommendations? Thanks!
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
Writer/Teacher
Do you mean distributors, or manufacturers?
Weltmeister and such are the obvious manufacturers... but otherwise I would direct you to Paragon Products, Rennbay, Broadfoot Racing...
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944. |
That Guy
*****************.com is a great place for all of your needs.
Before i start throwing out ideas, how much money are you looking to spend?
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Thanks Fusco, Rennbay and Broadfoot are what I had in mind.
Yeah, hit Paragon, he's got everything you need.
One recommendation for you in selecting mods - I highly recommend that you plan to do such mods as to be legal within a race class, if you're building a dedicated track car. That way it'll be easier to either a) sell the car to someone who wants to race it, or b) race it yourself when you get tired of just turning laps. I wouldn't bother with the brakes; the Rennbay kit is sweet, for sure, got it myself, but the stock brakes don't exactly suck! Just put on race pads, braided stainless hoses, and good fluid (ATE). Springs, bars, and good dampers (I do recommend the Bilsteins, that's what I'm running on both my street and race cars). 400# front spring and 30mm rear torsion bar is stiff enough to give you everything you need on the track, and could certainly be tolerated on the street. I just moved on from that setup to 660/34 for my racecar. Definitely gonna need suspension bushings, old rubber will do you no favors in the twisties. I recommend some sort of plastic; stock rubber is nice but not for the track, and solid is awesome but too expensive. You will probably also want the KLA solid upper strut bearing too. So just get the suspension set right, put money into shocks, and don't worry about brakes or drivetrain as long as they're properly maintained and reliable. The limits of the car will be quite high at that point. Feel free to follow up w/ email if you like...
Vaughan Scott http://www.vaughanscott.com http://www.924.org |
Great advice, thanks Vaughan!
That Guy
Vaughan, can you tell us about the Rennbay brakes? Your one of the few people who i see have them (a couple of guys on Rennlist have them, but havent installed them yet). I know the stock brakes are good, but are the Wilwoods that much better?
Fade resistance must be excellent, how about brake feel? Shorter stopping distances?
I just wish I could tell you... but they're going on my project 931 GTR/GTS Hybrid. That's a long way from hitting the road, possibly years away - it's gotten badly stalled by budget, as my wife's been unemployed for a couple of years now.
First step is to rebuild engine and turbo, install IC, and convert to EFI, repainting the engine bay in the process. Then it gets bodywork - the GTR IMSA kit from GT Racing - and paint, and could finally be driven.I would expect no improvement in stopping distances - that's all tire and suspension, not brakes.
Burn the fire.
There's also Elephant Racing. They have a nice polybronze and monoball setup that's very well priced. I installed these for a 911SC customer and the ride was significantly better than the stock rubber or poly-urethane bushings.
I think they also offer progressive springs and a rear-coilover setup. http://www.elephantracing.com/suspension/diagram/944suspensiondiagram.htm
[x] Working | [_] Broken: 2017 Victory Octane [x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi "Drive it like you stole it." |
From what I've heard, the parts Elephant Racing makes are the best and I believe they're a bit cheaper than the equivalent parts from Racer's Edge.
-Ian
Stock 1988 951, TT aero wipers |
Doing a suspension all at once is the best way, everything can work together.
Bilstine cup is a great system and within 30% the price of a Koni sport with coil over. Lindsay racing Paragon Pelican 944 online all good suppliers I recommend you do a search this and other popular boards about Broadfoot before you send them any money. First move I would make, Sway bars with good bushings. No doubt about it. Cheep, easy and makes a big improvement with or with out other mods. Good luck, have fun! ps be shure all the maintenace is good to go. |
White and Nerdy
I'm also looking at making my 944 a bit sportier. The front struts are old, and will need replacement soon. I was thinking of going with the Bilstien route mentioned. my mom's S2 has them all around, and its gota lot of bite
I'm looking at upgrading the front first, as it needs new struts, and doing the rears later. 1986 944. Car has P-zero's, 8.5" wide rear, 7.5" front, 17" diameter ROH Cup wheels. |
How about our host - Pelican?
George Roffe |
I mentioned Pelican right off the bat. I'll buy everything I can from them, but there will probably be some parts I need that they don't carry, hence my inquiry.
By all means, I'd do business with Paragon. I just didn't want to be rude to our host.
Paragon rocks.
George Roffe |
