-   -   How bad is this noise (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/247093-how-bad-noise.html)
Taz's Master 10-20-2005 04:38 PM
See if you can diagnose this. Kind of a rattle in neutral. Clutch in noise goes away. In neutral move the shifter almost into 1st, noise goes away. Sounds bearing-like (Not really a shift rod banging noise, but that would be my choice if I get to pick the source). Noise also goes away if I give it some gas. When the noise is alarmingly loud, pumping the clutch a time or two can reduce/eliminate it.
Last winter I did my clutch could it be a bearing in there? Possibly tranny related (the noise really travels up and down the torque tube)? How about this, this summer I replaced my clutch master cylinder. I now have a good bit more free travel in the pedal, could this being out of adjust cause a problem that would make a symptom like this?
Any help or direction would be appreciated, thanks.
BananaClip 10-20-2005 05:11 PM
I have the same thing, but it has always been my understanding that --AND CORRECT ME IF IM WRONG-- its fifth gear rattling around because there's some weird design flaw with the transmission on these cars and it is normal.
if not, torque tube bearings maybe?
yellowline 10-20-2005 06:48 PM
Throwout bearing?
jgporsche 10-20-2005 07:45 PM
I agree with yellowline, throw out bearing; although the throw out bearing is normally changed out at clutch replacement time. I think a bad throw out bearing may effect (damage) the pressure plate but not positive.
Taz's Master 10-21-2005 04:30 AM
I honestly suspect the throwout bearing (which I did change with the clutch), but any other suggestions would be appreciated.
I kind of figured it was that noisy 5th gear thing, but it's gotten louder which makes me think that this should get some attention. The torque tube possibility is a consideration. I have a spare one I may try to rebuild and install if I need to pull everything apart again.
Taz's Master 10-22-2005 11:03 AM
One more, if indeed it is the throwout bearing, since I replaced it with the clutch, what could cause it to go bad? Should I pay particular attention to something specific when I endeavor to replace it again?
