Brighter Gauges Idea
Since that http://www.flamingeye.co.uk/ is no longer taking orders I am going to have to do it myself the clarks-garage way.
However, he said he tried a reflective paint like chrome or aluminum and it didn't work well, he didn't say why. So he just taped aluminum foil over the surface that needs to be reflective and said that worked fine.
I don't really like the idea of taping foil to it, it just seems, well, rigged.
What about using metal tape like this
Anyone see a problem with that?
Old 10-20-2005, 09:45 AM
I used exactly that, and I don't think it worked that well. The sticky side just isn't as reflective as the non-sticky side. However, it does apply nicely and adheres quite strongly.
I'm going to remove the lenses and paint the area under the lenses white, which should significantly increase light output. I'm also going to resilver the initial reflector under the black cover. I'll tell you how it goes later today.
I'm hoping to be able to replicate his results with $10 in LED bulbs and some labor, but we'll see.
-Ian
Stock 1988 951, TT aero wipers
Old 10-20-2005, 10:05 AM
Tapage's Avatar
Send a message via ICQ to Tapage Send a message via AIM to Tapage Send a message via Yahoo to Tapage
someone try little mirror cuts in the reflective parts .. ? I already use the alum foil with no really good results .. I thought mirror is a way ..
David Alonso De La Vega Tapage
Panama
944 Turbo
Old 10-20-2005, 11:12 AM
Good idea, you can buy small mirror squares like 1/2" x 1/2" at the craft shops. I may get a bunch of those and glue them on
Old 10-20-2005, 01:04 PM
Burn the fire.
Brando's Avatar
I did like clark's garage... double-stick tape on aluminum foil that was polished up nicely.
I ordered 3 replacement LEDs (my far left bulb is burnt out). It's easier that way.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 10-20-2005, 05:10 PM
Mein Gott!
Panzer909's Avatar
Nobody here had good results with aluminum foil per the Clark's Garage method?
I tried it and it was night & day, IMHO. Big improvement. But then again my dash lighting was almost non-existant to begin with
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 10-21-2005, 05:27 AM
I didn't have good results, but I used the sticky side of the aluminum tape, and I think that didn't work well. I think polished aluminum foil and double stick tape would work much better. After taking out the reflectors completely, the sticky side of the aluminum tape is not much shinier than what was left on my stock reflectors.
Also, without removing the black cover, you can't redo the initial reflector, which was in bad shape on mine. I would recommend everyone remove at least that black part. If you do it carefully, it'll pop right back on fairly securely. Its just there to protect the silver coating when the gauges are being removed.
-Ian
Old 10-21-2005, 09:34 AM
aribop's Avatar
I used a sheet of plastic mirror like material that can be cut. Cut it to fit over the triangular reflector after cleaning with acetone. glued it on the sides sparingly with superglue. Covered all the lense assemblies with black tape to avoid any light leaks.
Works great!
I also have the Flamingeye kit and let me say it is definitely worth it! I'm glad to see his issue is temporary. I would hold out until he starts taking orders again.
'95 993 Monster in the making
'89 S2/Turbo aluminum grill monster: terrorizing another state
Old 10-21-2005, 02:17 PM
Here is the final result of my work:
It looks pretty similar to the flamingeye kit pictures, which was my goal.
Basically, I removed the reflector and put aluminum foil on the bottom in addition to redoing the top, and installed some super wide angle 5-led bulbs from superbrightleds.com. I also painted the hole the bulb sticks into with a bit of white paint to help it reflect a bit more, but I don't think that mattered that much.
It looked equally bright with the stock 2w bulbs, so if you don't want to change the color of the illumination, just do this and keep the stock bulbs.
As you can see, the rest of my dash now looks really dim in comparison. Any fixes for that?
-Ian
Old 10-22-2005, 12:47 AM
Here are a few pictures of what I did. I'm also uploading another picture of the result. It looked Ok on my computer, but worse once uploaded.
Result:
Putting reflective tape on the underside of the plastic lenses:
The reflectors being redone:
Everything back together:
I also did an A/B comparison of painting the area under the lenses white versus using reflective tape, and I felt the reflective tape was slightly better, though both were a big improvement over black. Also, reflective tape is easier if you already have it lying around.
I also compared the two types of LED bulbs I bought, and the 5LED super-wide angle ones with LEDs mounted sideways were better than the 6LED ones with all of them pointed forwards, which is what I expected. The LEDs I bought are $2.79/each + $5 shipping.
-Ian
Old 10-22-2005, 12:24 PM
Tapage's Avatar
Wouuu .. last saturday I try to do the same thinig .. but poor result in my case .. alum foil, but I thought the goal are the bulbs ..
did you buy this ones .. ?
http://www.superbrightleds.com/specs/r2415_specs.htm
Panama
944 Turbo
Old 10-24-2005, 01:07 PM
No, I believe thats just a raw LED. You need LED bulbs which are made for 12v car usage.
I recommend the WLED-x5 on this page: http://www.superbrightleds.com/specs/bulb_specs.htm
-Ian
Old 10-24-2005, 01:48 PM
Tapage's Avatar
you bought those ones ..
WLED-R5
Panama
944 Turbo
Old 10-25-2005, 10:28 AM
Yes, I bought Red, so I guess they are WLED-R5's.
Old 10-25-2005, 10:40 AM
So the good news is that my lighting is working out well.
The bad news is that my voltage gauge is messed up. It appears to be weak or sticky. It doesn't go all the way down after turning off the engine(unless you tap on the plastic) and it will jump up to 10 when starting, then slowly move up to 12 when running, but no higher.
Any ideas what I might have damaged and how to fix it? The car starts fine and I checked my battery, so there aren't any real problems.
Old 10-29-2005, 12:35 PM
