Porsche Crest 944 motor What year is it rebuild or replace seals( new to forum)
Well Finaly decided to join the forum, Because now I need advice of my fellow 944 owners Because i can't figure this one out myself.
Here's " the list "
I just bout a 84 944 motor ( looking at the intake manifold it has vacume hose under it like in 85.5 model and up ) well atleast the guy i bought it from said it was and 84 with 84k miles on it, how do i know of the year for sure?.. got it for 560 buks and has been sititng for 2 years. Oil looks clean looks to have updated water pump and apears not to have any oil leaks other then buy the Oil pour spout. What shoudl i do?
1 Put not seals in front n back of engine belts that kinda thing
2 Rebuild the motor completly?
3 Rebuild the motor in it now and jus swap out?
Since it out in the open replacing seals np i've dont it before but. Will it be ok since it's been sititng for botu 2 years
J
Old 11-05-2005, 11:31 AM
The engine number gives the year. As you don't even know if it will run, I would do a leak down test first.
Before it goes in:
Timing and balance shaft belts, rollers, front seals, water pump, flywheel seal, cam box gasket (the one to the head, check the lifters while apart), oil pan gasket, oil cooler seals, oil filler tube o-rings, inspect and change the rod bearings. Change the Motronic cooolant sensor.
Obviously: change the cap, rotor arm, plugs oil and filter.
Or just put it in and hope for the best...
What's wrong with the one in the car?
By the way, non-running (broken belts) or broken trans 944s are worth about $500
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 11-05-2005, 11:40 AM
The engine i have now I have no idea how many miles it has.. It has a lifter knocking sound near piston #4 Has an oil leak somewhere Very slow and oil doesn' thit the ground it just trail backwarkds under the chasis, Cleaned the motor once It may be leaking oil near the oil cooler and has oil around the top balance shaft and all around the Oil tube where you poor the oil. i belive i got oil on spark #1,#2 I Have a New trans about 130k(300$) lot's of parts have white paint on um ( looks to be serviced ), Oh yeah and the engine idles about 800 rmp realy rough maybe a vacume not sure
Jaime O.
Thank god I crashed or i would never have owned a porsche
83 944 daily driver (clutch and tt time)
85 325e BMW T-boned R.I.P.
Old 11-05-2005, 12:06 PM
I would get the engine looked at by a Porsche and 944 experienced technician, that doesn't mean a "we do German cars" type of shop.
It may be cheaper to fix the engine you have rather than spend more putting in an unknown unit.
Doing a basic diagnosis: compression, leakdown and fuel pressure test of the engine you have will give some answers.
Old 11-05-2005, 12:41 PM
Thanks Mr Britwrench I apreciate the input
Jaime O.
Old 11-05-2005, 12:52 PM
