 Rear sway bar?
		hello,
	can i easily upgrade my 14mm rear sway bar to a 18 or 20mm 951 rear sway bar? if so, for the a combo, what would be a suitable sized front sway bar? i have an '80 924 turbo with early style 924 front sway bar and pre 1985.5 style 924/ 944 style rear sway bar. TIA!  |
 Posted on another line
 Yup, everything bolts right in.
	You might need new hanger bushings, depending on how much bigger you want to go  |
 if its a 18 or a 20mm, what would be a suitable size for the front?
 There is no factory 20mm bar, your choices for rear bars are 14mm, 16mm, 18mm and a 19mm adjustable bar.
	I would base my decision on the front bar based on what the factory used. So with an 18mm bar i would stick with the following front sizes, 23mm 24mm 25.1mm 25.5mm You should select which one based on your preference. I would personally go with a 25.1mm front or 18mm rear. That is the same setup used on the later '87+ 944 Turbos. Those are all the front sizes that the factory used with a 18mm bar. You can see a indepth chart here, http://www.tech-session.com/kb/index.php?page=index_v2&id=23&c=4  |
 ok, the guy whos sending me the rear sway advertised it as a 19mm but i think it could be an 18 as he has an '86 turbo. hes just agreed to sell me his front sway bar when he upgrades in a few months time, he has a 24mm front bar.
	cheers for your help guys, and that chart! Awesome!  |
 The front-rear bias will affect the oversteer/understeer characteristics on your car. That being said, I am running a 26.8mm front bar with the 19mm rear and don't notice any unwanted understeer. Might make itself seen on-track, however...  |
 The only 19mm bars from the factory were 3-way adjustable. You can tell from the 3 mounting holes on the bars endlinks. You need to take into consideration the bar is painted with black paint. That may throw off your measurements slightly.
	To my knowledge there is no aftermarket 19mm bar. Aftermarket sizes start at about the same size as the smallest front stock diameter bars... 22mm! A rear bar that large will need to be offset by the huge aftermarket sizes of a 30+mm front bar.  |
 yeah, it may be the paint throwing off my measurements
| All times are GMT -8. The time now is 07:25 PM. |
