Parking brake shoe adjustment 1989 944S2
I just changed the rear rotors out on my 1989 944S2 but cannot see how the emergency/parking brake is adjusted to final setting after the rotor is installed. There are no ports on this model either in the rotor or in the hub to allow insertion of a screwdriver to turn the star wheel adjuster. Also, does the orientation of the star wheel adjuster (cup side to rear or cup side to forward) matter?
-Black on black 89' S2 |
There are holes in the hub. Are you sure you put the disc in the right postion, in other words are both the securing screw holes aligned? If not they are on wrong.
The position of the adjuster doesn't matter.
From November 2012; Precision Porsche Specialist Sussex UK, +44 (0)1825-721-205 2001-2012 Gerber Motorsport Inc. 206-352-6911 07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red 08.16.09 1999 Kawasaki ZRX1100. Green. |
