-   -   powerprom switch location (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/250072-powerprom-switch-location.html)
Eldorado 11-07-2005 03:46 PM
has anyone tried mounting the switch for their power prom on the center console near the wiper switch? what kind of switch did you use?
NKN84944 11-07-2005 04:13 PM
Wow that is actually a really good idea. I didnt get the dual adapter board, but if I did I would certainly look into this possibility. Maybe you could find a used wiper switch since it is only two position, and figure out a way to wire that in. It would definitely be sleek.
Brando 11-07-2005 05:06 PM
If you've got a spare switch slot open on your dash area... you could use another power mirror switch. Maybe put some sort of on/off indicator for it so you know which mode you're in. This would work for early and late :)
Techno Duck 11-07-2005 05:40 PM
I thought about putting a switch in the center console, but i have to many nosey passengers that like to play with stuff when they get into the car. Any type of two position switch will work, i had this one on my desk that was never used for anything. Its a aircraft grade switch, a bit overkill...but its the only use i can think for it!
http://img.photobucket.com/albums/v1...4/IMG_1917.jpg
Eldorado 11-07-2005 08:05 PM
he gave me a switch with the chip and adapter board... but if i could use a "stock looking" chip (the LED indicator is a great idea..) then i'll definitely consider it.
