fast924S's Avatar
Send a message via AIM to fast924S
Fuel lines
Hey guys, I was just looking into replacing my fuel lines (lines to fuel rail) and started to notice that my lines come from the d/s and go into pressed fittings into hard lines. They do not come from the p/s fender like so many 944, Whats the deal with that? Also how hard is it to replace these lines, How do I remove the old lines? They dont look like they unbolt. Thanx for the help, I just dont feel like screwing with it and figure some one here has done it before
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 11-17-2005, 03:17 PM
maybe its a euro model and set up that was for rhd?
Old 11-17-2005, 03:44 PM
pay someone to do the work,450.00 there abouts.... if your car catches fire , they buy you a new car
1988 924s mars red
coastal cruzer
Old 11-17-2005, 05:06 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
The early cars (and I believe the 924s models) ran the fuel lines along the belly, up the firewall and over from about the brake booster area (driver's side) around the back of the engine to the fuel rail. Why on earth they changed the design in the later 944s to run it directly above the exhaust headers is a mystery. I like the early setup WAY better personally.
Anyway, I believe the early lines have to be cut at a hard line junction and spliced onto - not a job for the amateur or faint of heart. I'd either pay someone or depressurize the fuel rail and get cutters and a flaring tool.
Black Cars Matter
Old 11-17-2005, 05:30 PM
fast924S's Avatar
Yea I like it better then over the exhuats manifold. I also dont have a problem doing it since I am a toyota tech and work on cars all day, I just didnt know if anyone has done it or has tips on what to do. But it lloks like Im just gonna hve to dive head firts into it and hope I do it right the firts time
Old 11-17-2005, 09:19 PM
Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
BTDT.....Yes the lines are a PITA to replace due to space at the rubber to steel connections. You have to cut the old line off w/o cutting into the hard line. This is hard as space is tight and hard to get a tool in to cut, but doable. The steel lines must be released from the holding clips so you can move the lines as you work. The new line then slide on and new clamps are used. You can get the lines from Travis on the list.
Also try to drain the fuel out the tank end of the lines first so when you remove the old ones you have less spillage around the bellhousing otherwise the gas will poor out when you remove the line.
Dal
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 11-17-2005, 11:55 PM
aribop's Avatar
Travis only has fuel line kits for the '85.5+ cars at the moment.
http://www.rennbay.com/fuel-lines-c-35.html?osCsid=f29d6cb7ee350c8fc37f90af6fde37d7
'95 993 Monster in the making
'89 S2/Turbo aluminum grill monster: terrorizing another state
Old 11-18-2005, 07:22 AM
