Fender Installation
So I'm finally getting around to replacing my busted up fender. The process seems relatively straightforward, but I'm a little uncertain about what substance I should be applying to the seam between the fender and the body when I install the replacement. Is it just silicone sealant or something else?
83 944 NA - daily driver
Old 07-13-2009, 09:43 PM
Just make sure there is no rust where the two mateup. You can use tape to mark off the areas and use Rustolium (sp). Let it dry and use a thin coat of RTV. Hope this helps.
Cheers,
Larry
Old 07-14-2009, 11:07 AM
rickharrison's Avatar
Or seam sealer...found at any auto parts store. Its what its for.
Rick Harrison
1988 944S
17 inch Cup 2's, euro bumper conversion
Magnaflow 2 1/2" exhaust with K & N 4 inch custom intake
MaxHP chipped
Old 07-15-2009, 07:29 AM
