Tapage's Avatar
Send a message via ICQ to Tapage Send a message via AIM to Tapage Send a message via Yahoo to Tapage
Cold Start
Hi all folks .. when you try to start your Porsche ( 951 in my case ) did you depress the throttle pedal .?
Yesterday morning and today I have had to give 2 or 3 ( today ) attemptts to start it after a cold night ( cold here in Panama is about 20C - 70F )
the first time, it start but down after few seconds .. the second attemptts the same situation but more seconds at very low rpm .. finally the engine stop ..
At 3rd attempt, the engine still running ( at low rpm ) but slowly goes up .. all with throttle pedal untouched.
David Alonso De La Vega Tapage
Panama
944 Turbo
Old 11-01-2005, 08:25 AM
Eldorado's Avatar
it's been down to sub 10C here already in Toronto, and my car has started just as it would in 20 and 30 degree weather...
how many cold cranking amps in your battery? i bought a nice beefy 650A a couple months ago that seems to be doing the job nicely.
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 11-01-2005, 09:37 AM
Send a message via Yahoo to bigyagi
yes, quite the range here in southern ontario, from +35c/90% humidity, to something like -30c in winter! anyhoo, never had problems with cold starting, although the power steering does whine like a badly adjusted timing belt, for the first minute or so.
always make sure that your alternator is giving good output, and battery in great condition. i also go down to 5/30 grade oil. this helps.
glad i dont live in alberta, where they get a real cold dose.!!!
1984 944 na.
FR. WILK power prom/dual chip.
2005 buick. daily beater
2002 grand am--better halfs ride.
olds 98 royal brougham--gone, but not forgotten.
Old 11-01-2005, 04:52 PM
Eldorado's Avatar
panama is slightly different than southern ontario
i love how he says it's getting cold - 20 degrees!!!!!
Kyle
Old 11-01-2005, 05:08 PM
bearone2's Avatar
Cool
the manual recommends not stepping on the gas pedal when starting.
87 951, K27/6, Almond Beige, 17" Turbotwist
87 944S, alpine white, 5sp died a violent death
84 944, silver/brown, auto, gone but not forgotten
"may the force be with you"
Old 11-01-2005, 06:07 PM
White and Nerdy
Tervuren's Avatar
My question, is how long ago was thel ast itme you started it?
Shadilay.
Old 11-01-2005, 07:13 PM
Tapage's Avatar
Thanks all for the replyes ..
My 951 is my DD and after first start in " my cold " morning, all other starts throught the day comes fine and at first attemp ..
My Batt is relative new ( one month ) Motorcraft with 650 CCA ... 20W-50 my actual oil grade ..
Panama
944 Turbo
Old 11-02-2005, 07:37 AM
Had the same problem. Fixed it by redoing the the the valves. Had a bent valve
Old 11-20-2005, 01:36 PM
