944 Alarm Problem. Advice needed.
Ok so I bought a third 1989 944 with an alarm. I do not now if it's factory or not.....
The alarm starting going off...Its one of those alarms where the horn just doesnt stop. the car would crank, but not start. We disconnected the battery, but as soon as we reconnected it, the horn started going off again and the car would not start....Anyone have any ideas as to solve this? We do not have a remote for the car, and I don't know if it ever even had one. Thanks in advance.
Old 06-15-2008, 03:25 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
bypass the factory alarm first off. process is on www.clarks-garage.com
If it's not the factory alarm and an aftermarket one, post back. Most install shops put starter kill relays in.
most alarms will also fault back to whatever they were doing before they lost power so that would be normal and correct.
Is it the normal car horn or does it sound like a different kind of horn? That can also tell us if it's factory or aftermarket.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 06-15-2008, 04:36 PM
The horn that is going off is located behind the battery
Old 06-15-2008, 05:19 PM
Definatly sounds aftermarket.
You will need to find the alarm. Check up under the driver side dash. Might be about 2"x4" and have a bunch of wires coming out of it. If they put one that's made by DEI I can help you out, if not then check out www.the12volt.com
86 Metallic Grey
Old 06-15-2008, 05:42 PM
ednj's Avatar
Not to hyjack this thread but has anyone here ever seen one of these?
I bought this car with no info, so I just don't touch this dial pad.
1986 944 black
1987 944 red
Old 06-15-2008, 05:59 PM
In the Fires of Hell.....
kdjones2000's Avatar
If it's the horn behind the battery, then it probably IS the factory alarm.
The alarm module is located under the DME, in the passenger footwell. Look at Clark's as mentioned above for the process to disable.
This is assuming of course that you have the factory alarm key and the key slot (The one in the DS quarter panel) is in the vertical position. If it is horizontal, then the alarm is active.
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 06-15-2008, 08:09 PM
Factory alarm is run through the car horn, which isn't near the battery.
86 Metallic Grey
Old 06-15-2008, 08:20 PM
dsalillas's Avatar
On my 90 S2 the alarm horn is behind the battery and yes it is factory. I've had to unplug it several due to a bad alarm relay.
84 944 (RIP)
85.5 944 (RIP)
88 944S (about to be parted)(traded for S2 Engine)
90 944S2 Cab. (finally running after head surgery)(now with a new engine)
Old 06-15-2008, 10:39 PM
earlr85944's Avatar
I agree, the factory alarm on all 944's I have seen has a seperate horn for the alarm located in the cowl area. Is there a lock located to the right of the drivers side door? If so then you can remove it and simulate a "key off" by opening or closing the contacts on the back of the switch, dont just ground the 2 wires it shouldnt work.
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 06-16-2008, 07:12 AM
Do you guys have pictures of this? Cause with all the cars I have had or parted out I have never seen a seperate horn unless it was after market. And they all had the factory alarm.
86 Metallic Grey
Old 06-16-2008, 08:51 AM
Proprietoristicly Refined
John_AZ's Avatar
It is probably similiar to this UTube one.
http://www.youtube.com/watch?v=YW9thRHzYyg&feature=related
From the video, the back of the keypad may have the dealer info.
Good luck-Looks like it has been disconnected.
John_AZ
Old 06-18-2008, 04:35 PM
Those are old alarm start kill systems. Real old actually. It should just interupt the starter, so removing it and putting things back together shouldn't be too much of an issue.
86 Metallic Grey
Old 06-18-2008, 04:40 PM
earlr85944's Avatar
"Do you guys have pictures of this? Cause with all the cars I have had or parted out I have never seen a seperate horn unless it was after market. And they all had the factory alarm."
I dont have any pics but you can verify this with the factory wiring schematics
83 944....bye bye
Old 06-19-2008, 03:40 AM
Paul_Heery's Avatar
Item #3 in this pic
Old 06-19-2008, 05:51 AM
