clutch pedal to the floor #2
Hello All,
My 968's clutch went to the floor, I pulled it up and tried to use it to nurse the car home. The petal now will/cannot be press in, no matter how much pressure one puts on the petal...
Any ideas?
TIA,
Peter Voss
Old 06-17-2008, 09:22 PM
Parrothead member
VINMAN's Avatar
Most likely the clutch master cylinder took a dump.
Vinny
Old 06-17-2008, 09:45 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
It's either the master or the slave, or you have air in the system.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 06-18-2008, 07:52 AM
vott does ziss do?
ronin's Avatar
ditto. just did one on a Silver Rose here at the shop. the pressure hose from the master to the slave burst. do both the master and the slave at the same time, even if only one or the other is bad. it saves time later
Old 06-18-2008, 08:48 AM
Thank you to all for your advise!
Take care,
Peter
Old 06-18-2008, 08:40 PM
Nobody Special
Are you saying the pedal is locked in the 'up' position now and will not move at all? If so, I don't think a failed hydraulic component will lock up the pedal. If the pedal is stuck 'up' I would think it's a mechanical issue even though I've never heard of that happening. Loss of hydraulic pressure would make the pedal stay down not up unless the MC rod has popped out and is jammed against something.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD
91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD
86 - 951-K26/8, daily driver-SOLD
87 - 944S - Another daily driver-SOLD
Old 06-18-2008, 09:49 PM
