Pics of wet rear footwell
Here are some pics of my car rear passenger footwell when it rains. It has to be coming in from below somewhere and only in one spot. My drains are not clogged, but im am unsure of what to do with the 2 drain hoses under the hatch passenger side-the black one and the yellow-white one. Also, the last pic is of the hole under the dash that i had a problem with but i fixed.
Old 12-08-2005, 08:16 AM
Parrothead member
VINMAN's Avatar
looks like mine! except i usually have a inch or so of water in it.
Vinny
Old 12-08-2005, 09:54 AM
Back from Beyond
Mine? Fibreglassed battery box, replaced rear window seals, problem solved. It was mostly the window seals (I think I've said this before here...)
Good luck!
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 12-08-2005, 11:42 AM
Z-man's Avatar
This is what I did: the 'saddlebag' storage compartment in the rear fenders have a rubber plug on the bottom - I removed it. Let's face it - a 15+ year old hatchback is going to leak a bit. It's more difficult to track down the leak, than it is to let the water leave!
At one point, I had a couple of inches of water in that area.
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 12-08-2005, 12:50 PM
earlr85944's Avatar
reminds me of when I worked as a mechanic for an industrial plant, when plumbing had a leak the mechanics would solder or replace it, the technicians would shut off the water.....
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 12-08-2005, 01:05 PM
Just in case you guys missed this...
The spoiler on the 944 has two small slits near each corner designed to drain away water which would accumulate on the glass back where the rubber spoiler and glass meet. Make sure those are open, dirt tends to plug them over time. A plastic butter knife will work fine and prevent damage. When these drains are open water does not collect on the spoiler. This should help prevent water from finding a way into the hatch cabin.
AJF
1998 Glacier White Boxster
1971 Fiat 124 Spyder
1999 Mercury Mountaineer
Old 12-08-2005, 02:40 PM
Send a message via AIM to michaelathome Send a message via Yahoo to michaelathome
IIRC there are 2 holes under the carpet in the back seat. Service holes of some sort. climb under there and make sure that they are not missing their covers. It is VERY likely that the water is actually coming up from under the car if this happens while driving. It is also likely that your sunroof linds are plugged or not draining to where they should be. Make sure that you check those. You are going to have a mess under there iand in a hurry if you don't address the problem. Ask me how I know. :P
Michael
Old 12-08-2005, 03:55 PM
ilikemy944's Avatar
Send a message via AIM to ilikemy944
Mine has a leaking hatch seal, and that same spot is wet.
Brad Tompkins
Current: '86 951 Sunroof Delete - '89 951 - '83 944 Spec - '08 Cayenne Turbo
Past: '88 924S Track - '86 944 16v - '87 951 - '87 951 - '88 951S - '08 Cayman S - '87 944 Track - '93 968
Old 12-08-2005, 04:33 PM
About those lines... I think they may not be draining where they should be. There are 2 places to stick the lines through and their is also a small drain hole on the bottom of the'saddlebag' storage compartment in the rear fenders. Should i push the lines through the rubber plugs on the side or let them rest and drian through the small drain hole on the bottom? The black one was plugged in but my yellowish one was just dangling. It has to be coming from the bottom though because i pushed my passenger seat as far back as it can go and it rests right on top of the water spot. No water is on the seat though, so it has to be coming from underneath. I dont think its a window seal problem. Maybe it from those "service holes".
1983 Porsche 944
Old 12-08-2005, 04:35 PM
SoCal Driver's Avatar
The white plastic is the sunroof drain. The black is the gas filler/expansion tank over flow drain. Push them through the grommets.
Check that the top of your doors seal. Seen bent window frames let water in at the top rear.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-08-2005, 05:20 PM
Kevin0323's Avatar
Pearljaman,
Take the yellowing hose and connect one end into the hole and the other into the male connection (black) just underneith the hatch locks on both sides.
Thanks Ferrara_racing for the tip on the spoiler. Mine were clogged pretty good.
Old 12-09-2005, 09:55 AM
Tapage's Avatar
Send a message via ICQ to Tapage Send a message via AIM to Tapage Send a message via Yahoo to Tapage
those rear windows seal is a god tip .. I'm gonna check ..
David Alonso De La Vega Tapage
Panama
944 Turbo
Old 12-09-2005, 01:39 PM
