-   -   Blinkers not working but hazards work??? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/253296-blinkers-not-working-but-hazards-work.html)
fmalgapo 11-26-2005 07:02 PM
Anyone ever come across this situation in early 944?
My blinkers are not blinking, but when I depress the hazard switch, it will work. When i have left or right selected on stalk, the blinker indicator light on the gauge will be solidly lit yet the outside blinkers are not flashing. The relay is working when hazard lights are working. I checked the switch itself, and the operation seems to be fine, making contact and all since the light stays solid when left or right is selected, just no blinking on the outside of the car.
I am not sure what to check out?
AFJuvat 11-26-2005 07:14 PM
You probably still have a bad flasher relay.
AFJ
Eldorado 11-26-2005 07:15 PM
or your indicator switch is goofed up....
edit: hmm, ignore this post.. perhaps i should have read your whole post first. lol :p
pokey 11-26-2005 07:18 PM
Are you testing with the ignition on or off? If it's off, they are doing what they are supposed to.
fmalgapo 11-26-2005 07:38 PM
Hey guys quick responses!!
I also notice with ignition off and i turn the stalk left or right, my parking/indicator light stays on for just that side? Is that euro parking lights?
I have tested with ignition on AND off...
with ignition on, blinker left or right, solid light on gauge, but nothing blinking outside
with ignition off, blinker left or right, parking lights will be solidly on for that respective side
My stalk is allegedly brand new says the PO (my bro). I have removed it/reinstalled it twice and see that its making proper contact. Ordered a relay, lets see how that goes... AGAIN my hazards do work, but individual blinkers do not.
pokey 11-26-2005 07:42 PM
Wierd. Yes, euro parking lights.
PhillysMostWntd 11-27-2005 11:43 AM
had the same problem, i replaced both the switch and the relay, it was bad wiring the whole time, i just wished i would have checked that before buying everything else
fmalgapo 12-03-2005 08:05 AM
Can you tell me where you found the wiring to be bad? I just replaced my relay and still no blinking, but hazards work...this is killing me!
PhillysMostWntd 12-03-2005 03:35 PM
the shop who put in my new transmission rewired my blinkers, it was only $60.. id check around at local shops
Jmasters 12-03-2005 10:29 PM
I had the same problem it was a loose connector on the back of the fuse box
