Lose the ABS
My '87 944S (w ABS) has serious brake line *issues*(rusty lines eveywhere)--Has anyone gone back to just straight brakes?
Problems, issues?
Thanks,
Jeff
Jeff Laurence, '87 944S
Old 11-29-2005, 06:51 PM
Will removing the brake lines cure the "brake issues" ?
If the lines are rusty, they need replacing. If the flexible hose are original replace those too. Once replaced with the correct type of lines, pressure wash the underside of the vehicle and treat everything with a corrosion-preventive wax (Wurth makes one) and then do the same proceedure regularly. Had to do this in the UK to prevent the front to rear and fuel lines disappearing due to corrosion. Although the car is galvanized, all the bits bolted to it aren't.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 11-29-2005, 07:32 PM
Send a message via AIM to hpaulb
Couldn'tbelieve when I worked on my 87 how good it was. Not a spec of rust. Didn't stop the mechanic doing the safety check from telling me I needed a new rubber flex line. I changed both cheap ~20 can. each and got the opportunity to drain/change out a lot of the old brake fluid. Still can't figure out why I had to change it? Looked perfect. Of cource there are a lot of garages that come up with a list of bull to make some money. Was he ever surprised when I showed up with a dolly to take it have and do all the work myselfe.
87 924S 107k (miles) yellow
1969 Firebird Coupe (Full frame off restoration.)
98 BMW 740i
2020 Subaru Outback and 2019 Crostrek.
Old 12-01-2005, 11:12 AM
