bajabubba40's Avatar
Front brake calipers
I had a brake job done ... new rotors, pads, ets. and now the calipers look like they are not retracting enough.
Hydraulics look fine so we figure it must be the calipers. The problem is that we cannot find caliper rebuild kits for the S2.
Help anyone
Old 12-06-2005, 08:56 AM
Send a message via Yahoo to wizkid918
what do you mean not retracting enough? if you mean the pads are still touching the rotors, and you can hear them rubbing if you turn the wheel by hand. thats normal for a new brake job, especially with new rotors too.
Old 12-06-2005, 10:59 AM
..P ..P is offline
It sounds like the piston isn't retracting properly, and in my experience, taking a big C clamp and pushing the piston all the way in, and then giving it a shot of Gibbs, will solve the problem.
Here is a photo pictorial of doing this job on a 928. The results worked fine.
http://www.network54.com/Forum/message?forumid=426130&messageid=1126987073
If you drive with a stuck caliper, it can heat the disc so hot it will warp it, and also potentially set the car on fire.
P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 12-06-2005, 03:22 PM
Lightbulb I will this a try ...
Thanks, I am concerned about the potential for overheating the pads. I've already dumped over a grand in these brakes and don't want to dump another grand if I can avoid it.
Cheers
Bubba
Old 12-08-2005, 02:45 PM
lubing pistons not the problem
We bleed everything and lubed the back of the pads and they appear to retract properly but when brakes are applied then they tighten up and then they don't retract properly. Maybe the retainer springs????
Any other ideas???
Old 12-27-2005, 12:09 PM
924Sracer's Avatar
Sounds to me like your pins are grooved. You may need to grind down the shoulder that develops or replace them.
2001 Tacoma 4x4 extra cab SR5
1988 944S- for sale
1988 944- parting out
1987 944- parting out
1987 924S- sold to a friend
1986 944- Turbo Black on Black
want to trade parts?
want to buy parts?
I have a ton of parts
E-mail me por924sracer@aol.com
Old 12-27-2005, 12:58 PM
The kit includes piston, seal and dust seal; I have recently bought some for the rears and know they are available for the front.( as the dealer ordered these by mistake, first time round) Sometimes the brake pads are gripped by the stainless plates screwed to the upper and lower faces of the calipers, corrosion can occur between these plates and the aluminium caliper, causing the plates to tighten onto the pads.
944s2
Old 12-27-2005, 12:59 PM
gadgit's Avatar
Remember, the callipers on the S2 are different from the others.
4 pistons and the instructions say you should not split them apart.
Make sure you don't make a silly mistake working on these.
Make sure you are talking to someone who has worked on the S2, I also believe the Turbo has the same brakes ?
gadgit.
Old 12-27-2005, 03:49 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
