-   -   Wrong Throttle Return Spring? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/254934-wrong-throttle-return-spring.html)
livewirevoodoo 12-06-2005 05:12 PM
Ordered & recieved a new throttle return spring as old one had a little slack in it.
After recieving spring, I realized I ordered 944-110-071-00. The 2nd part number listed in the PET was 944-110-071-01 (and had the comment "AUT" in the lefthand column). I'm assuming this denotes automatic, which is what I wanted.
Inspecting the 2 springs, both are same size, length, gauge, etc., with the only difference being that one end of the wire hook (the end connecting to the cam) is slightly longer on my older auto-specific spring.
I installed the new one with no adverse effects.
Should I be concerned at all to return it for correct part #?
nynor 12-06-2005 06:52 PM
nope.
livewirevoodoo 12-06-2005 07:33 PM
Thanks. Only think i could think of was the spring snapping loose and being thrusted into WOT... lol
fast924S 12-06-2005 08:50 PM
I wouldnt worry about it, As Long as it seems to be installed ok and feels good then roll with it
