-   -   who makes Mo30 caliper adapters for std 944 turbo's? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/255211-who-makes-mo30-caliper-adapters-std-944-turbos.html)
NICKG 12-08-2005 08:46 AM
I am wanting to swap up to m030 brakes and am looking fro an adapter for putting the radial mount 928s4 brakes on my 91 s2...anyone? I tried calling broadfoot, but no response or replies from email or messages. I am looking for the whole conversion, i am hoping that the adapter will allow me to just use the m030 rotor and caliper while keeping the original hub...anyone?
928ram 12-08-2005 12:00 PM
There's an outfit caled 928 motorsports: www.928motorsports.com that sells a set to adapt the S4 calipers onto 928s with the early sliding type, might be the same thing that you are looking for for the 944.
NICKG 12-08-2005 12:18 PM
that is not what i need exactly. I have std 944 turbo brakes, not the iron calipers. kinda the same but not right (the spacing is wrong).
WaA420 12-08-2005 12:53 PM
Any place that sells the '87 up 951 big red kit will have those adaptors. Or just step up to the plate and buy the correct spindles, but last time I bought a set they didn't give them away.
NICKG 12-08-2005 01:01 PM
it would be that way, but the hubs are $ too. if i could find someone with the front set used, i would buy it just too damn exensive new from dealer. I want to keep the 16" wheels so big reds are not gonna work. Most places didn't know if the adapters they had would fit the s4 calipers or work ,,,or if they could sell just them
WaA420 12-08-2005 08:01 PM
Lindsey has the aluminum adaptors for $150. I'll check and see if the big reds and the 928S4 calipers have the same hole spacing but I think they do.
aribop 12-08-2005 08:59 PM
Yes, the hole spacing is the same.
NICKG 12-09-2005 09:19 AM
i cannot seem to find any info on Lindsey Racing
aribop 12-12-2005 10:17 AM
go here: http://www.lindseyracing.com
IanS 12-12-2005 10:34 AM
What calipers do the lindsey adapters work for? What about Boxter calipers or GT3 calipers?
NICKG 12-12-2005 10:57 AM
no sense using boxster ones...s4 or gts for me. the std s2 or turbo has the same size pad i think as the boxster....
