Heater blower not working
Got in the cab tonight for a drive, went to turn the blower on to heat the inside up but it would only operate on number "4" on the heater blower knob.
Haven't checked the fuses etc yet as it was dark - heating is fine - nice and warm but the blower wouldn't operate on anything other than the highest.Is this a cmmon problem with s2's?
1989 guardsred 944s2 cabriolet,
1983 metallic claret 924 lux (sold)
Old 12-09-2005, 04:13 PM
is this thing on?
NICKG's Avatar
you need a resister pack...no biggie there
"People willing to trade their freedom for temporary security deserve neither and will lose both"
~Benjamin Franklin
Old 12-09-2005, 04:20 PM
Thanks nickg - where abouts is the resistor found then?
Old 12-09-2005, 04:30 PM
is this thing on?
NICKG's Avatar
it is on the (in england) driver side. it has a wireharness with a flat plug on the end that goes into it. it has 2 phillips(cross headed) screws holding it in. 2 minutes to change it.
~Benjamin Franklin
Old 12-09-2005, 05:11 PM
Is that on the inside of the car or under the hood?
Old 12-09-2005, 05:15 PM
is this thing on?
NICKG's Avatar
oopps...sorry under the bonnet on the fan housing by the battery
~Benjamin Franklin
Old 12-09-2005, 05:20 PM
Thanks mate - i'll have a look first thing in the morning.
Old 12-09-2005, 05:22 PM
Just got the resistor out and soaked it in white vinegar - haven't tested it yet but it doesn't look too good - not sure what the coating is around the large coils but it's heavily cracked although the coils aren't damaged.
Old 12-10-2005, 05:12 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
I think the coating is just a ceramic that keeps the coils in shape/from shorting into each other. I wouldn't bother messing with it just replace it, sounds like you have a corroded solder joint or something and soldering nichrome is damn near impossible.
nate
1988 944... and a bunch of other cars
Old 12-10-2005, 05:17 AM
Refitted it and it's working fine now - another problem in life solved!
Old 12-10-2005, 08:07 AM
