-   -   Torque Values Needed (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/255589-torque-values-needed.html)
Pete Pranger 12-10-2005 05:01 PM
I need the correct torque values for the following:
1. Main bearing studs
2. Remaining bolts on crank girdle
3. Rod Bolts
Thank You for the help
Pete
NKN84944 12-10-2005 05:28 PM
What yr and model do you have?
Pete Pranger 12-10-2005 05:47 PM
Sorry, that would probably help.....
1987 944 N/A
Pete
Pete Pranger 12-14-2005 01:38 PM
Nobody has ever changed the bearings and used a torque wrench to reassemble these things?
Anybody got a good guess? JK.....
gadgit 12-14-2005 02:51 PM
connecting Rod nuts. Smooth nut type 46 lbs.
Ribbed nut type 59lbs.
What size are the Crank nuts, (Crank lower to upper section)
12mm 15, 29,then 55 lbs or 10mm 15, then 37 lbs
there are also additional 8mm 15 lbs, 6mm 7 lbs.
I suggest you doulbe check the above from another source to confirm that the above is what you are after.
As I am English your terms are slightly different, so doulble check !!
