Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Marcelh's Avatar
Unhappy Cigarette Lighter not working
My Cigarette Lighter in the 87 924S quit working and cannot figure out why
all fuses seem o.k. and everything else works so does that mean the actual lighter assy needs replacing??
It has never been used for cigarettes and looks brand new inside and yes it has worked before I used it last winter for a heated seat cover and wanted to use it this winter again.
Also just remembered that if I ever have a flat that I need it to pump the spare tire up!!
Any help is appreciated.
Thanks,
Marcel
1997 Porsche Boxster Red
1993 Porsche 968 Red
1988 Porsche 944 Metallic Gray
1987 Porsche 924S Red
1987 Porsche 924S White
Old 12-14-2005, 07:57 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
SoCal Driver's Avatar
Your car is telling you something -- get a chest x-ray.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-14-2005, 08:07 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
pokey's Avatar
Send a message via AIM to pokey
I'd guess the wire came lose off of the unit, being that it wasn't used for cigs.
Still looking for the right deal on another P-car
1968 BMW 1600 2 liter
1956 Ford F250
1955 BMW R69
1999 Range Rover Callaway #011 of 220 (Yeah, as in Callaway Corvette...)
Old 12-14-2005, 08:11 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
OK. I'll get the x-ray.
Old 12-14-2005, 09:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
pokey's Avatar
SoCal, please do. We don't want to lose another one of the '44 gurus. Also, come out to the next gathering o' '44s, have a couple beers, and put faces with screen names/avatars.
Marcel, You'll need to pull the socket to test if it's the wire, or the socket itself, or some where else in the wiring. But, I'd start at the socket end with a test light.
1956 Ford F250
1955 BMW R69
Old 12-14-2005, 09:28 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Was thinking of a head x-ray and not a chest as I have never smoked. But I did grow up in a smoking household.
Old 12-15-2005, 08:16 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
pokey's Avatar
Ahhhh...
1956 Ford F250
1955 BMW R69
Old 12-15-2005, 10:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Easy for you to say!
Old 12-15-2005, 11:29 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
pokey's Avatar
Actually, that was me trying to breathe after growing up with a father who smoked four packs a day, and a mother smoking two. I feel your shortness of breath...
1956 Ford F250
1955 BMW R69
Old 12-15-2005, 11:34 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Mother made it to 62. Then got the hole in the neck when they took all of her vocal cords and stuff out. We swear she still would smoke for the next year and a half it took her to die.
I have back ground asthma. Comes on with heavy colds and such. A real pain.
Back on subject: What was being plugged into the socket? I know that one of the cell phone chargers I have just will not stay in. The other does. Could have fried the socket.
Old 12-15-2005, 06:17 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Marcelh's Avatar
I plugged a set heater into socket last winter and it worked fine.
This year I tried again but does not work.
How do you tell if socket is fried? I would think that fuse would
blow before it would fry a socket?
By the way the socket looks o.k. by looking at it, clean and shiny.
Marcel
Old 12-16-2005, 12:15 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
After the Xray and normal smacking:
Check Fuse #7: Also controls Radio, Clock, and Inside lights:
After that, check that you are getting voltage to the socket.
I think there are two slip on spade type connector behind the console that also might of come off.
Bad connectors usually have brown marks on the nice clean shine where Mrs. Electricity was up to mischief.
Old 12-16-2005, 04:33 PM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Marcelh's Avatar
So does anyone know how to remove the lighter assy to inspect the wires?
Does the whole center console panel need to be removed?
Thanks,
Marcel
Old 12-16-2005, 07:59 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Eldorado's Avatar
is it possible that your seat warmers are broken and not your lighter socket?
Kyle
2008 Mini Cooper // '83 Porsche 944 // '01 Mazda Protege [sold] //
"Never break more than you fix!" - SoCal Driver
Old 12-16-2005, 08:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Marcelh's Avatar
No the lighter does not work either!
Marcel
Old 12-17-2005, 07:51 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
