-   -   how do i turbocharge my 951? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/256899-how-do-i-turbocharge-my-951-a.html)
nynor 12-19-2005 08:58 AM
Originally posted by Z-man
Can someone start a post on how to turbocharge their 944 n/a or something??
Thank you,
-Z-man.
just kidding!!!
ajajajajajaja!
Z-man 12-19-2005 09:21 AM
If I may quote what Tifo has stated in the past -
Here are the steps to upgrade a 944 n/a to a 951:
1. Open hood of your 944 n/a.
2. Locate the coolant overflow tank. It's that yellowish plastic tank just behind the driver's side headlamp unit.
3. Carefully remove the overflow tank cap. Note: do not do this while the engine is still hot. Wait for the motor to cool down.
4. Take overflow tank cap and find a 951.
5. Place cap on coolant overflow tank of the 951.
6. Drive off in your upgraded car.
Congratulations! You have upgraded your 944 n/a to a 944 turbo!
-Z-man.
nynor 12-19-2005 09:23 AM
LOL!!
Porsche-O-Phile 12-19-2005 09:48 AM
Wouldn't work - the n/a reservoir cap is inferior to the turbo one and will never stand up to the extra power.
Z-man 12-19-2005 11:14 AM
Not necessarily - if you've got an M030 spec cab from your 944 n/a, is should work just fine on the 951, unless, of course, the 951 has the upgraded 951-M030 spec cap. Then, indeed, you're 944 cap may not be able to withstand the increase in pressure. But a 968 M030 3-way adjustable rear sway bar (set to the middle setting) should be able to compensate for the inferior cap. Unless, of course, you have a limited slip differential.
But I digress...
SmileWavy
-Z-man.
Moneyguy1 12-19-2005 11:16 AM
So much pressure..so little gain.....
Eldorado 12-19-2005 03:30 PM
and if all else fails...... this should work....
Dean924s 12-19-2005 08:08 PM
Just add one of these.
http://www.marx7.org/%7EDSMITH/vortech.htm
BananaClip 12-19-2005 08:16 PM
It does! I saw an early in a junkyard once with one of these right after the 944 badge.
d.a.autry 12-19-2005 09:20 PM
Ya, know.
I won't bet much, maybe a buck or so. . . but I'd be willing to bet, with money not being the object, I could get 200hp out of a NA 2.5L. . . no added turbo, no supercharger.
Let's see:
Up compression, around 10:1 or 10.5:1
More duration and lift
cat test pipe
headers
big bore throttle body
Port/Polish (again, for what polishing worth on an engine that isn't torn down and cleaned every 500 miles)
Delete the balance shafts
Hotter ignition
Custom chip designed for mods
Recalibrated MAF (this can be taken into account in chip programming though)
Better intake (K&N or the like)
But the real question is . . . . .WHY!!!!!!
ilikemy944 12-19-2005 09:55 PM
Hmm.
I took the resevoir cap off my n/a to put on my 951 because the 951 one wasn't holding pressure.
So does that mean my 951 is not longer turbocharged?
Eldorado 12-19-2005 10:02 PM
no, it means that it's a TURBO turbo charged... dude! you're pushing the envelope!
Rmills944 12-20-2005 08:17 AM
Originally posted by ilikemy944
Hmm.
Have you not been listening? That makes it a turbo'd N/A
..P 12-20-2005 08:54 AM
http://img.photobucket.com/albums/v4...e/036631dc.jpg
Regards, P
ilikemy944 12-20-2005 05:49 PM
Hmm, the KLR box is not in that picture
seaboltman 12-20-2005 06:52 PM
I would say that to turbo a 951, you have to add blinker fluid. Its the best and easiest way to turbo your 951
Eldorado 12-20-2005 06:53 PM
how about ajajajajajajaja fluid?
PhillysMostWntd 12-20-2005 08:34 PM
you need ajajajaja fluid to make ANY car even run
you amateurs know nothing!
combine ajajajaja fluid with "NOS" decals and you will be seeing some serious numbers.
http://www.pelicanparts.com/support/smileys/ar15.gif http://www.pelicanparts.com/support/smileys/rlwhore.gif
d.a.autry 12-20-2005 10:03 PM
I thought you only used that for a better stroke!:eek:
d.a.autry 12-20-2005 10:08 PM
I know you've already seen it, but I just had to pull it back up.
http://www.angelfire.com/nc2/mycoffeecan/page1.html
