Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
rudidelange's Avatar
how do you remove a stuck cylinder head?
My cylinder head is stuck. I have removed the 8 nuts, the 2 smaller bolts at the front, the manifold and h20 pipes. Even removed the waterpump in order to tap the head from below on the front 2 tabs. I have used a pry bar on the 4 different corners and the head appears to be loose on the exhasut side, oil and water leaked from it. The inlet manifold side does not want to move.
What next, your help will be appreciated.
1983 944 RHD Original. Uses all my spare cash!
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 12-19-2005, 09:43 PM
AFJuvat's Avatar
There are a total of 10 head nuts on the head, are you sure you got them all?
If you are sure that you have everything, just keep tapping - sometimes they get stuck.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-19-2005, 10:09 PM
Deplorable Member
Porsche-O-Phile's Avatar
Don't forget the bolt at the front that always snaps and requires you to buy an extra $200 worth of taps and punches and drill bits and drill the old one out of the block.
'74 911 Targa 2.7 (in storage, hoping to finish "someday"), 2001 Mercedes SLK 320 (with a few AMG fun bits), '85 BMW K100, a few surfboards
Black Cars Matter
Old 12-20-2005, 05:26 AM
SoCal Driver's Avatar
Shaped explosive charges. Solves lots of problems.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 12-20-2005, 11:08 AM
Razorback1980's Avatar
Send a message via AIM to Razorback1980
When I took my head off, I double nutted the studs and removed the studs making the head much easier to break loose and it didn't have to lift up either which made things a bit easier as well.
Tom
Old 12-20-2005, 11:14 AM
earlr85944's Avatar
can you post some pics?
if all is removed, bolts, belts, manifolds etc, then prying should remove a stubborn head unless there is some serious mechanical damage holding it in place (not likely). Reseat the head by pushing it back down and try prying a little at a time from side to side, if one side is pryed too much and the other side is left "low" it will bind. Careful not to pry on the head mating surface. Why are you removing the head.
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 12-20-2005, 03:07 PM
Thanks earlr85944 and others
I was able to remove the head after 6 hours work. A black deposit, looks like oil/carbon was stuck between the 3 centre studs (at the inlet side) and the top. I placed a pry bar on two corners at a time and was able to loosen it a fraction. Pushed the head down and then took about 5 hours removing the deposit between the studs and top with small fine pieces of steel and needles.
After that I was able to remove the head.
1947 Morris Sold
1972 Benz Sold
1975 Benz Sold
1976 Benz Sold
1977 Benz Sold
Old 12-20-2005, 09:38 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
