Certified Rennwerker
924Sman's Avatar
Send a message via MSN to 924Sman
Tool needed....crunch time
Snap On is no where near me and I need the 12pt 8mm CV socket drive. I need one now where in the world are these things? Google for cheesehead sockets and I get the Green Bay Packers. Snap On Catalog does not show them. I cannot find a single place that has one or is there a more official name for it because I can't find it under cheesehead,allen or hex or Torx.
These sockets must be banned in Iowa
PCA " I've been everywhere, done everything......just can't remember any of it!"
Old 12-30-2005, 02:37 AM
pep boys has them in a 3 pack 12mm, 10mm and 8mm.
Rick
99 996C4
06 525XI
87 944S - Sold
77 924 - Sold
Old 12-30-2005, 03:56 AM
Cars & Coffee Killer
legion's Avatar
They are under a different name at most auto parts stores...and I can't recall what they are.
I think they are also used on air-cooled VWs, so maybe they are listed under that application.
I had to order my set from the store's catalogue, they didn't stock any.
5 liters of VVT fury now
-Chris
Old 12-30-2005, 04:42 AM
They're called Triple-square bits.
If you look at one carefully, it looks like 3 square drivers all on top of each other, and offset a little
Mike
'92 968
'01 VW Jetta TDi
Old 12-30-2005, 04:59 AM
legion's Avatar
There was a third name that was neither triple-square not cheesehead. I'll look at my set when I go home today...
-Chris
Old 12-30-2005, 06:36 AM
Send a message via AIM to toolboy62 Send a message via Yahoo to toolboy62
I just bought some at my local Carquest. They are made by Lisle if that helps any.
nate
1988 944... and a bunch of other cars
Old 12-30-2005, 08:29 AM
AFJuvat's Avatar
XZN fittings.
carquest should have them - as well as any VW shop.
AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 12-30-2005, 09:02 AM
Here's a pic for ya. I found these at autozone for around $10. I haven't used them yet so I can't vouch for their quality, but I'm going to be doing my CV's also....real soon.
Old 12-30-2005, 11:00 AM
924Sman's Avatar
MacTool guy stopped in to save the day! 16 bucks delivered to my door...So I am good to go folks......thanks!
Mac calls them VW Velosity socket
Old 12-30-2005, 11:08 AM
Granite 944's Avatar
Yeah, aint that something. They are called by many a different name, and RARELY if ever, "cheesehead", anywhere but on these forums, and in the PET software, and FSM. The rest of the world, doesn't recognize it as such.
Lets see, what are all the names they ARE called by? (add to the list if you've heard others). Of course, there are a few different types of configurations of these, ie, socket drive types, and wrench types.
I know there are more than what I've put below, but.........
1: Cheesehead
2: Triple square
3: 12 point internal serrated
4: 12 point hex
5: "VW Velosity socket"
6: ?
1985/1 944 Granite Red (wife's car. Iceshark is lighting her way)
1983 944 Platinum (my daily)
1985/1 Guards Red (project)
Old 12-30-2005, 07:39 PM
Send a message via Yahoo to 912E TKT
I can't tell you how grateful I am I found this on this board. I got a set of VIM Triple squares and striped the 8mm XZN driver after one bolt.
Old 03-24-2007, 03:44 AM
meister member
speedracing944's Avatar
I bought a set of 4 triple square sockets from Snap On for $110. I wish I knew of a different source when I bought mine. $110.. OUCH!
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 03-24-2007, 04:46 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
napa sells it for like 7 dollars, it's called an '8mm serrated wrench' tool, on their napa service tools rack.
add that name to the list!
Mike - Flight Instructor, A&P Mechanic, Fuel Injector Service Specialist
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
'99 VW Cabrio - green/tan - daily beater
'83 944 - zermatt silber/black - Dad's 40k mile time capsule. purchased in 09-1998 @ 18k
Old 03-24-2007, 05:42 AM
SoCal Driver's Avatar
Originally posted by Granite 944
6: ?
6: = !!@%*&&@#$%$#@!!
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 03-24-2007, 09:01 AM
winter-hater club member
nynor's Avatar
i was worried about getting this tool. the guys at motorsports suggested that i crawl under there and make sure the bolts hadn't been changed. sure enough, they were allen heads.
"COOL PRIUS!" - Nobody Ever
Old 03-24-2007, 09:19 AM
It looks like the Pep Boys triple sq tool is okay.
This is just a messy job. I will never do this again without a lift or pit.
Old 03-24-2007, 10:35 AM
nynor's Avatar
i'd heard this was a messy job. i'll be doing it myself, tomorrow. how messy is it?
Old 03-24-2007, 11:05 AM
The dust from the clutch disk cakes up on the surfaces and comes down all over you along with any grease and road grim. Wear goggles and a mask. I am sure breathing this stuff is not good. You will be so covered with grim that your wife will not let you into the house.
Steve Patrick
92 968 Cab
76 912E Sunroof Coupe
68 912 Targa
68 911 Coupe
Old 03-24-2007, 11:19 AM
Politically Incorrect
onZedge's Avatar
Add "spline bit" to the list.
Edek
'87 924S
'91 535i
Old 03-24-2007, 11:32 AM
Okay so I got the car all put back together but now I have no clutch peddle. I bled the line and tryed to adjust the peddle. No luck. I adjusted until the shaft left the peddle pivot. Anyone else have this happen?
Steve Patrick
92 968 Cab
68 912 Targa
68 911 Coupe
Old 03-24-2007, 04:52 PM
