Writer/Teacher
CJFusco's Avatar
Send a message via AIM to CJFusco
951 Exhaust Manifolds
I got in a set of exhaust manifolds (bought from a Pelican member) to replace my cracked set (crack or bad gasket on the #1 cyllinder manifold).
The new set has a ribbed area (the word "baffle" comes to mind, but I'm not sure if that's correct) on the #1 cyllinder manifold, but my car's stock manifolds don't.
My car is a 1986, the first year for the 951. Is this ribbed area on the manifold simply an improvement that was made to the pipes' design over the course of the car's development? If so, what is the purpose of this ribbed area (I wouldn't doubt it if it had something to do with heat dissipation)?
Current Stable: Black 07 Porsche 987 Cayman S: Long-Tube Headers; FabSpeed Exhaust; VividRacing ECU Tune; IPD Plenum; 997GT3 Throttle Body. Blue 1983 Porsche 928S. 1985.5 Porsche 944 Rat Rod. 2011 Acura MDX. 2008 Mazda 3. Gone But Not Forgotten:Garnet Red 86 Porsche 951("The Purple Pig"). Alpine White 83 Porsche 944 ("Alpine Wolf"). Guards Red 84 Porsche 944.
Old 06-02-2007, 09:52 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
yes, it is a design improvement meant to keep from cracking, commonly referred to as a 'bellows' style manifold. i believe '87 and later were fitted with them.
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 06-02-2007, 10:22 AM
Writer/Teacher
CJFusco's Avatar
Not surprising, considering that it is my #1 manifold that is cracked.
Old 06-02-2007, 08:06 PM
ERAU944's Avatar
aye... whatcha gonna do with the old ones?
Old 06-02-2007, 08:20 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
For the record CJ, I was a little concerned about the #1 header wiggling around a little by the baffle but I learned that's normal to prevent cracking when they heat up. Enjoy!
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 06-02-2007, 08:42 PM
Coming up on your left...
Aufgeladen944's Avatar
Send a message via AIM to Aufgeladen944
Hmm I think I need to buy a new manifold. Mine has a crack in it, too.
Funny thing is, it's the later style one that came on the Turbo S (I have a Turbo S engine). I was told $500 to fix it, or $1000+ for a new one.
1986 Porsche 944 Turbo "S" clone
1998 Honda Accord
Siena College '08
Manager, Mavis Discount Tire
Old 06-03-2007, 07:09 AM
Writer/Teacher
CJFusco's Avatar
I would recommend finding one from someone breaking down a 951...
Old 06-03-2007, 07:17 AM
Perhaps, but wouldn't buying a used one potentially have the same problem, or soon afterwards?
And how hard are they to get off of there?
1998 Honda Accord
Siena College '08
Old 06-03-2007, 01:43 PM
ERAU944's Avatar
they are a PITA to get out of an N/A, i can't imagine removing from a 951 (sooner or later i'll get around to doing mine, not looking forward to it ). the ones he bought are the revised design, not (as) susceptible to the cracking/leaking
Old 06-03-2007, 07:12 PM
TNT25169's Avatar
A PITA? I removed the ones from both my '89 944 and my '87 951 with the engines still in the car in less than 30 min. I've had worse things to remove from the car....
www.apartabove.com
Old 06-03-2007, 09:06 PM
ERAU944's Avatar
i guess i should say the *can* be a pita. one of the exhaust studs on the 951 is broken... i'm not looking forward to the job.
Old 06-04-2007, 06:07 AM
Writer/Teacher
CJFusco's Avatar
I am planning on tackling the job tomorrow (day off), and I was planning on just going in there, hitting the necessary bolts with some liquid wrench and an impact wrench, and then just pulling off the necessary pipes.
Is there anything else I should keep in mind? I can see why bolts might be a pain, but I'm not sure why taking off the pipes would be a HUGE PITA...
Old 06-04-2007, 06:19 AM
The problem is getting enough room to get them off of the studs and out of the car. Some have found that unboltling the motor mount on the passenger side and raising the motor slightly provides the necessary clearance. Good luck, it is not fun.
I have found that taking the 2-3 off first and then the 1-4 works well.
Old 06-04-2007, 07:26 AM
Writer/Teacher
CJFusco's Avatar
ClarksGarage recommends removing the studs from the assembly by backing them out of the housing using two nuts. This, I suppose, would make removal easier.
The site also states that I MIGHT have to remove that coolant pipe that runs over the manifolds. Might? Has anyone had to do this?
Old 06-04-2007, 07:56 PM
That is about the only way to remove the factory studs, but if you really take your time, you should be able to get them off w/out having to remove the studs. It can be done. Also, I am not a big fan of pulling and replacing studs in our aluminum heads. Its just too easy to strip the threads in the head since the aluminum is realtively soft compared to the studs, my .02.
I really can't imagine trying to get the headers off w/o removing the coolant pipe. Once the headers are off and the coolant is drained to remove the coolant pipe, its a good opportunity to do your oil cooler housing seals as well!
Old 06-05-2007, 03:54 AM
Writer/Teacher
CJFusco's Avatar
Hmm. I wasn't planning on draining the cooling system, but I guess it's really no big deal.
The only coolant I really have in stock is the orange Dex-Cool stuff. There's no problem with using this, right?
Old 06-05-2007, 07:51 AM
Not sure about that. The coolant you want is the type that is phosphate free.
Old 06-05-2007, 09:47 AM
Politically Incorrect
onZedge's Avatar
GM Dex-Cool is fine, however, do not mix Dex-Cool with anything else but Dex-Cool in the future because it may gel when mixed with other antifreeze formulas. Prestone 5/150 is also acceptable, cheaper and compatible with other fluorescent green antifreeze formulas. I like to buy the 50/50 premixed versions as they are already cut with demineralized water. Do not use tap water in the radiator - and especially the battery. Mineral content of tap water is commonly too high.
Edek
'87 924S
'91 535i
Old 06-05-2007, 10:57 AM
Writer/Teacher
CJFusco's Avatar
thanks for the info; maybe you can help with my latest quandary:
Stumped!
Old 06-05-2007, 11:03 AM
