Crazy idle hard thingymobobber thing.
Hi. Ive been on here a million times with tons of problems but i keep having this recurring one. At start up my car idles hard, and will easily stall out and die if i dont slightly keep my foot on the gas to properly idle it. I have to quickly put it in gear and get going. If i can drive it for about 10 seconds down a road it goes away and fixes itself to idle either around what it should, or slightly a little more. Its a 5spd 83 944 with 70k. I do need a timing change and i believe one or a few of my injectors has a problem (like its working on only 3 cylinders at start up?). This has been happening every single time like clockwork at startup and then fixing itself pretty quickly. And i can smell the exhaust and gas every time i step outta my car or even when im driving. My car is unhealthy. (its running really rich or lean i guess) Im tired of driving like this. I love my car but i cant keep going through this stuff. Thanks.
1983 Porsche 944
Old 01-06-2006, 06:03 AM
SoCal Driver's Avatar
Replace your vacuum hose fittings 'Y' and 'U' on the lines to the fuel pressure reg and damper. Remove and clean your idle bypass control valve. Check the J boot/tube for hardening and cracks and poor tubing fits.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-06-2006, 07:09 AM
...or possibly the DME temperature sensor needs to be replaced. I guess often when they go bad they can cause a lean condition during initial cold startup/running. Once the engine starts to heat up the problem lessens.
85/1 - I just pushed my trip odometer while driving
Old 01-06-2006, 08:23 AM
