Dtchy's Avatar
Borla exhaust
Hey all,
I've been thinking of putting a new exhaust on my car and it seems the Borla (XR-1 or a different muffler) is the way to go. Anyone knows where these are for sale?
The Borla website does not show a catback for an 86 944na.
So should I buy the muffler, a tip and have the stuff welded together or any suggestions?
Thanks.
Joost
Horsepower is how fast you hit the wall...Torque is how far you take the wall with you...
1994 BMW 325is M-Technic
1986 Porsche 944 N/A
Old 01-06-2006, 11:03 AM
Dtchy's Avatar
Oh...and I need a high flow cat also (it has to be SMOG legal..).
Any suggestions?
Old 01-06-2006, 11:04 AM
I bought a Piece together Kit for a 924S 3" High flow with Magna Flow 40 series. Way to loud for street (but very fun!!!). I Also needed a big resonator to add a little back pressure to avoid a few HP loss low end . I ended up not using kit cause it didn't bend correctly as it should of wrapping around the rear suspension and CV. And now I'm stuck with $300 worth of pretty pipe. Use a custom exhaust shop and take your favorite muffler, mounts, and Cat and maybe resonator. Mine was just $300 for continuous pipe with no junkie bolt ones. I'd probably get a bolt on High flow Cat since they could later be swapped in 3 years or so, after they're toasted. Make sure the shop knows in advance they'll need the flanges to mate, if ya do or more waiting.
I think all cat's are legal by nature. Shops usually have the tip for another $60+. ASK local PCA or hot rod guys what's good in your area for a shop and generally stay away from the big name company's. Well that's my 2cents. Good luck.
Old 01-06-2006, 11:26 AM
Rmills944's Avatar
Send a message via AIM to Rmills944 Send a message via Yahoo to Rmills944
I got mine from SpeedforceRacing and it sounds absolutely awesome, just loud.
Ryan
'84 944 moneysucker edition (SFR, Corbeaus, etc.)
'02 Jetta TDI 280Lb/Ft 145Hp @ wheels. RC2 PP357's
Dtchy's Avatar
Thanks guys, I also saw the SFR sytem and I read some pretty good things on this board. It retails for $699 though with an XR-1 muffler. But I guess you get what you pay for. It looks pretty sweet though!
I'm even thinking about an OE replacement cat. The thing was that when I had it smogged a couple of months ago, my HC was right at the limit. Does anybody have a clue what could solve this? Is this a cat problem?
Old 01-06-2006, 11:50 AM
winter-hater club member
nynor's Avatar
could be a cat problem. could be running rich.
"COOL PRIUS!" - Nobody Ever
Old 01-06-2006, 12:00 PM
Dtchy's Avatar
Hmmm...I looked on the Borla website and saw the XR-1 mufflers. I'm even thinking about welding a new muffler on my old pipe.
What size casing would I need? 12"or 16"? What is the result of different case sizes?
Old 01-06-2006, 12:28 PM
The outside end before the tip needs to vertically line with the exhaust hanger. If your cutting new pipe it's that guys problem. If it's a Mod to your current, better keep the same length as what you got.
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 01-06-2006, 01:22 PM
