Send a message via AIM to fierochris Send a message via Yahoo to fierochris
944s heads
Can 16 valve 944s heads be used in place of 8 valve 944 heads?
if so then what gains would i expect?
71' 911T Targa, current toy.
86.5 928s traded for new 911
71 911 Targa w/ gas burners, PMO's, *sold*
Lamborghini diablo replica w/ 350 V8
85.5' 944 n/a euro ( gave to dad )
87 fiero cp. candy blue, chrome 16's
90' DSM 24psi. 18G fmic,
82' benz 300sd turbo, intercooled.
73' Karmann Ghia cab. sold
04' Standard 250s ox, euro bb 28/10 gearing, odyssey, profile, 29lbs,
check out www.vintagevwcars.com
wanted: 914, 944, 928 project
Old 01-06-2006, 06:58 PM
SoCal Driver's Avatar
Gains: $4,000 rebuilds when the cam chain breaks rather than the $1,500 for an N/A. Water jackets don't match on some blocks.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-06-2006, 07:02 PM
fast924S's Avatar
Send a message via AIM to fast924S
Lindsey Racing does do the machine work to make it fit.
http://www.lindseyracing.com/Merchant2/merchant.mvc?Screen=SFNT&Store_Code=LR
1986 951, Stock for now.
]87 924S Gaurds red- SOLD after 11 years of ownership
Old 01-06-2006, 07:09 PM
thanks for the link. great site, i gotta get that 3pc crossmember!
Old 01-06-2006, 07:52 PM
fast924S's Avatar
No problem. I think some guys over at rennlist.com Have had some talk about the swap but Im not sure. They where mostly thinking of using it for a 3.0L 16v 951 witch would be killer. In the 944 NA engine I played around on a engine program I had on my PC and the biggest restriction besides the AFM is the head. The head is very hard to make flow with a SOHC and 8v, its very hard to get a wide power band. So a DOHC would be sweet. Do some more searching and Im sure you will find more info.
Old 01-06-2006, 08:03 PM
it really nice to find someone so helpful on this forum.
thanks again.
Chris
Old 01-06-2006, 08:06 PM
fast924S's Avatar
LOL. no problem, Just about all the guys here a GREAT and very helpful, You just gatta give them a chance, maybe open a post that says HI or something, Problem is you just happened to ask the "Turbo My NA" question that just about everyone hears about once a week. Most of the peopl that ask it are silly 16 years olds that have no idea what a oil filter looks like let alone do a turbo conversion, But it seems you are one of the few that have some type of idea of whats involved. Anyway dont worry Im sure others will chime in with some SUPPORT sooner or later
Old 01-06-2006, 08:16 PM
well we will see tommorrow, if i get the 931 i think i could sell the parts
remaining for the rest of the funding i need to get the parts for the block and heads. do you think there would be enough interest n parts here
or should i take the ebay path?
Old 01-06-2006, 08:27 PM
fast924S's Avatar
I would just throw a post up telling everyone what your selling, let it sit for a day or so and if no one bites go to ebay
Old 01-07-2006, 11:29 AM
didnt get a chance to go and look at it today, spent the whole day
moving cars around the yard, had the get the 68' Javelin moved out
for Ian "operationcugar" hes coming up to pick it up next saturday
and i got two more fieros today and they took up the rest of the day.
its getting dark now so maybe tommorow.
Old 01-07-2006, 01:56 PM
PhillysMostWntd's Avatar
Send a message via AIM to PhillysMostWntd
hey my buddy has a fiero, are you well knowledged with the factory engine or just swaps??
hes having major problems with his TBI
1984 Porsche 944 - down for the count, may be rebuilt
1999 Civic ex coupe - Turbocharged fun/Daily Driver
Old 01-08-2006, 09:50 AM
..P ..P is offline
I recently asked a similar question about the 928, whether or not the 4-valve heads would fit onto an older 2-valve motor. The cam drive on the older cars is in the exact same location on the 4-v cars, and as you know, the secondary cam on the DOHC setup is driven off that first cam that's driven by the timing belt.
The answer I got was, "yes, it's possible, but you'd be better off getting a couple Euro cams and bolting them onto your 2-v motor". The Euro cams are a higher lift, and piston clearance would be a consideration.
P
1983 928S 5-speed, 1984 944, 1990 944S2 Cabriolet
My other car is a Chris Craft Commander
http://www.chriscraftcommander.com
Old 01-08-2006, 02:36 PM
P.. thanks for you reply my car is a euro car so there would be no need
to switch cams, i think im staying 8v and getting some lensay racing heads.
as for phillysmostwanted i have some knoledge of the stock motors
but mostly MFI 2.8 V6s and not a whole lot about TBI 2.5 4 cyls
pleae tell me the year of the car and explain the symtoms
Old 01-08-2006, 03:37 PM
read post below.. this one got goofed
Old 01-08-2006, 06:42 PM
its a 1984 2.5 4 cyl. he picked it up for $300... non running
has new plugs wires, cap, rotor, has not checked the fuel pump or filter (i think one of these or both are the problem), but fuel runs out of the fuel lines when they are disconnected (sorta), no gas is squirting out of the tbi when cranking, runs completly fine on starter fluid, he thinks the tbi is clogged as it sat for about 1 and 1/2 years, he got a tbi rebuilt kit and is gonna see if that works
everything else is pretty much ruled out, i think if the tbi rebuild kit doesnt solve it a fuel pump and or filter will. any other ideas on what it could be?
his throttle cable is completly torn apart too. some wires are disconnected here and there inside the car (we cant find where any of them go??) hes looking to do a v8 archie swap by the end of the summer, so some good info on that would be great too if you dont mind.
Old 01-08-2006, 06:45 PM
the 84' is the least reliable fiero with the most possible problems.
i dont even keep 84's unless they are one of the #2000 indy 500
pace cars.
the first thing to cheak with anything fuel delivery related are the fuses
the next thing would be to check your fuel lines from the sending unit
all the way to the throttle body. And BE SURE TO REPLACE THE OLD FUEL FILTER! oce you have checked all lines and hoses for crimps,cuts,and clogs then try agian if this does not fix it
then you will have to step to the next level of labor and drop the
tank and replace in tank filter (sock) and go ahead and replace the
fuel pump while you have the tank out DONT FORGET TO REINSTALL
RUBBER TANK SEAL there will be a new one with your new fuel pump
now try again. still not working? (unlikely) well the can only be two more
things next step replace tbi injector (rebuilt flow tested is fine) if that does not fix it then your ECM is all thats left.
or skip all of this nonsence for a friggin 95HP 4banger
and drop in a small or big block chevy using a mount and adaptor plate
kit for V8 Archie v8archie.com and feel the instant 300 percent boost
in power in a 300-1000 HP 2400LB street leagle go-kart!
the total swap would range from $2000-$4000 depending
on engine and kit choice.
and stomp just about anything on the road and be every bit as nimble
as original when its time to go auto crossing sunday!
Old 01-08-2006, 07:05 PM
p.s i do have a turbo 2.5 that may be availible for sale with rebuilt
motor, reprogramed ECM,turbo, and 4t60 tranny.
Old 01-08-2006, 07:09 PM
motor, reprogramed ECM,turbo, and 4t60 tranny. parts for my 944
would be considered as a option for trade on motor
Old 01-08-2006, 07:10 PM
i have the same thoughts.. with the money he is putting towards the 2.5 he should be saving it for a swap. hes already spent like $3-400
Old 01-08-2006, 08:25 PM
Cars & Coffee Killer
legion's Avatar
Hamilton, huh?
That's straight west of here, about 150 miles.
5 liters of VVT fury now
-Chris
Old 01-09-2006, 09:34 AM
