Burn the fire.
Brando's Avatar
Lightbulb 1988 (or late) Vacuum diagram
Having issues distinguishing which is which... This is the diagram I found via search:
Is that the right one for my model year? Also, which item on there is for the heater core valve? In the midst of my clutch job I either sheard a plastic line for vacuum or hooked it up wrong -- my heat is now on. AND BEFORE IT GETS MENTIONED no, the little plastic arm under the dashboard IS NOT BROKEN -- that part is fine. It is a vacuum routing issue.
Thanks!
~Brando
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 01-08-2006, 03:22 PM
